Max Doorrijhoogte a écrit :
> On Thu, 11 Mar 2010 19:46:47 +0100, Hueyduck <sea-(E-Mail Removed)>
> wrote:
>> PS: if you don't find the audio tweaks for XP, and if you do need them,
>> just ask. Someone might be able to post them here.
> .....to what kind of audio tweaks are you referring?
This one, for instance:
Processor scheduling should be set to background services and not Programs.
Start > Settings > Control Panel > System > Advanced > Performance
Settings > Advanced
Tab > Background Services
Here's the list I apply when I prepare a new PC (taken in 2003 from a
site called musicxp, or something).
For consistency, before carrying out the tuning tips suggested below,
switch to classic view in the
control panel. To do this, Start > Control Panel > "Switch to Classic View".
Then, switch to classic view for the menu. To do this, Start > Control
Panel > Taskbar and Start Menu >
Start Menu Tab > Classic Start Menu.
If you require further information on a particular tip, click on the
associated
1. Processor scheduling should be set to background services and not
Programs.
Settings > Advanced
2. Visual effects should be set to a minimum.
Settings > Visual
Effects Tab > Adjust for best performance
3. Switch Off Desktop Background Image
Right Click Desktop > Properties > Desktop Tab > Background None
4. Disable Screen Saver
Right Click Desktop > Properties > Screen Saver > None
5. Disable Fast User Switching
Start > Settings > Control Panel > User Accounts > Change the way users
log on or off >
Untick Use Fast User Switching
6. Switch Off Power Schemes
Start > Settings > Control Panel > Power Options > Always On > Turn off
monitor and turn
off hard discs to Never
http://www.musicxp.net/tuning_tips.htm (1 of 4) [26/10/2003 16:32:45]
Tuning Tips
7. Switch Off Hibernation
Start > Settings > Control Panel > Power Options > Hibernate > Untick
Hibernation
8. Activate DMA on Hard Discs/CD ROMS
Start > Settings > Control Panel > System > Hardware > Device Manager > IDE
ATA/ATAPI Controllers > Right Click Primary IDE channel and Secondary
IDE channel >
Properties > Advanced Settings Tab > Transfer Mode to "DMA if available"
for both
devices.
9. Disable System Sounds
Start > Settings > Control Panel > Sounds and Audio Devices > Sounds Tab
> Sound
Scheme to None.
10. Do Not Map Through Soundcard
Start > Settings > Control Panel > Sounds and Audio Devices > Hardware
Tab > (highlight
your soundcard from the list) > Properties > Audio Devices > (highlight
your soundcard
from the list) > Properties, and check the "Do not map through this
device" checkbox.
11. Disable System Restore
Start > Settings > Control Panel> System > System Restore Tab. Tick the
"Turn off System
Restore on all Drives"
12. Disable Automatic Updates
Start > Settings > Control Panel> System > Automatic Updates > Turn off
automatic
updating. I want to update my computer manually
13. Startup and Recovery Options
Start > Settings > Control Panel> System > Advanced > Startup and
Recovery Settings >
Untick Automatically Restart
14. Disable Error Reporting
Start > Settings > Control Panel> System > Advanced > Error Reporting >
Disable Error
Reporting
15. Disable Remote Assistance
Start > Settings > Control Panel> System > Remote > Untick Allow remote
assistance
invitations to be sent from this computer
http://www.musicxp.net/tuning_tips.htm (2 of 4) [26/10/2003 16:32:45]
Tuning Tips
16. Fix Swap File (Virtual Memory)
Settings > Advanced
> Virtual Memory Change > Custom Size. Set initial and maximum size to
the same value.
17. Speed Up Menus
Start > Run > Regedit > HKEY_CURRENT_USER > Control Panel > Desktop
Folder. Set
MenuShowDelay to 1
18. Disable Offline Files
Start > Settings > Control Panel > Folder Options > Offline Files Untick
"Enable Offline
Files"
19. Disable Remote Desktop
Start > Settings > Control Panel > System > Remote > Untick "Allow users
to connect
remotely to this computer"
20. Disable Internet Synchronise Time
Start > Settings > Control Panel > Date and Time > Internet Time >
Untick "Automatically
synchronize with internet time server"
21. Disable Hide Inactive Icons
Start > Settings > Taskbar and Start Menu > Taskbar TAB > Uncheck "Hide
Inactive Icons"
22. Disable Automatic Desktop Cleanup Wizard
Start > Settings > Control Panel > Display > Desktop > Customise Desktop
> Untick "Run
Desktop Cleanup Wizard every 60 days"
23. Disable NTFS Last Access Time Logging (NTFS File Systems Only)
Start > Run > regedit > HKEY_LOCAL_MACHINE > System > CurrentControlSet >
Control > Filesystem. Add a new DWORD value -
"NtfsDisableLastAccessUpdate" and set
value to 1.
http://www.musicxp.net/tuning_tips.htm (3 of 4) [26/10/2003 16:32:45]
Tuning Tips
24. Disable Notification Area Balloon Tips
Start > Run > regedit > HKEY_CURRENT_USER > Software > Microsoft > Windows >
CurrentVersion > Explorer > Advanced. Create a new DWORD value called
EnableBalloonTips and set to 0.
25. Disable CDROM Autoplay
Services > Cdrom. Set autorun to 0.
26. Disable Disc Indexing Service
Right Click Start > Explorer > Right Click Each Disc > Properties >
Untick "Allow Indexing
Service to index this disc for fast file searching"
http://www.musicxp.net/tuning_tips.htm (4 of 4) [26/10/2003
16:32:45]Tuning Tips
Tuning Tips
associated
Programs.
Settings > Advanced
Settings > Visual
log on or off >
monitor and turn
Tuning Tips
Hibernation
IDE channel >
for both
devices.
> Sound
Scheme to None.
Tab > (highlight
your soundcard
device" checkbox.
"Turn off System
automatic
Recovery Settings >
Disable Error
Reporting
assistance
Tuning Tips
Settings > Advanced
the same value.
17. Speed Up Menus
Folder. Set
MenuShowDelay to 1
"Enable Offline
Files"
to connect
Inactive Icons"
> Untick "Run
value to 1.
Tuning Tips
