On Wed, 10 Feb 2010 16:20:28 -0800, Robert Peirce wrote
(in article <(E-Mail Removed)>):
> In article <(E-Mail Removed)>, (E-Mail Removed) wrote:
>> Have been looking at some really good interconnects for my system;
> Frankly, for anything up to a meter I have never heard a difference.
> I'm not sure electrically you could unless the cable has some really
> weird topology.
By weird topology, it would almost have to be that external capacitors,
resistors and inductors would have to be added to the cable to PURPOSELY make
filters which would alter the frequency response of the interconnect. Simply
a 1 meter length of coax with RCA connectors on each end can not possibly
have enough reactance at any audio frequency to affect the sound in any
audible way.
> The longer the run the more likely you may encounter resistance,
> capacitance and reluctance issues, but it would take a really long run.
> I've been away from this too long to do the calculations. Maybe
> somebody else has it handy.
Capacitive reactance (X sub C) = 1/(2 Pi Fc) where F = the highest frequency
in the pass band, and c = the capacitance in Farads.
Inductive reactance (X sub L) = 2 Pi Fl where l = the inductance in Henrys.
Z (Impedance) = The square root of (R squared Times (Xl squared - Xc
squared))
Where R = Total DC resistance in Ohms, Xl = Inductive reactance in Ohms and
Xc - capacitive reactance in Ohms In a case where Xl is > than Xc. If Xc is >
than Xl, the formula becomes:
Z = The square root of (R squared Times (Xc squared - Xl squared))
If you use typical coaxial cable specs for C and L/foot, then at 20,000 Hz
(or even 50,000 Hz) the impedance is miniscule and attenuation is not enough
to make any difference whatsoever in the audio band for normal interconnect
runs. Now you get to 20 ft and more and it is measurable, but only as a loss
at extremely high frequencies and not likely audible. Extreme cases could
effect a very slight "dulling" of the highest frequencies that most adults
can hear, but no other effects.
The bottom line is that if you can hear, using controlled double-blind
testing, any difference between two interconnects or speaker cables it's
because one of the manufacturers has purposely designed the cable to
attenuate (that is, take away from) some portion of the audio spectrum and
this is NOT anything that one should want.
