trs80 wrote:
> Its an odd question I know, but Im locked into the Sun Solaris OS
> w/Sparc to do some basic 4 channel recording. Are you aware of any
> audio interfaces that are compatible with the Sun Solaris OS which
> uses the Spark processor? I have found a Sun Hardware compatibility
> lists for Solaris but using Intel X86. It could be any interface,
> PCI, USB etc. Thank you for any tips
A Fostex MR8HD is a cheap household quality harddisk-recorder with
usb-interface for direct drive access when importing to preferred DAW and it
will record 4 channels simultanously and has acceptable mic pres if you use
condenser microphones and will supply 48 volt phantom. If you want 24-96
there is for instance the small Edirol ... you can probably get an audio
interface cheaper, but then you still have to get it to function reliably
with no drop outs or clicks ....
Kind regards
Peter Larsen
