On Fri, 18 Feb 2005 09:34:03 -0500, Codifus <(E-Mail Removed)> wrote:
>mark e wrote:
>> After many years of service, I need to replace my CD player. Can I buy a
>> high end audiophile DVD player, and use it for double duty as a CD player?
>> I don't want to sacrifice the quality of a good CD player, because I play
>> more music than DVDs. But it would be easier to just have one unit.
>Other than the important factors of sound quality and features, the main
>thing you should think about is the interface. DVD Players tend to be
>built with the assumption that you will use your TV to select tracks,
>program, etc, whereas the CD player makes the best use of the internal
>(usually LCD) display. Of course some DVD players can be programmed
>without the TV, but the interface is usually wanting and has far fewer
>features than the corresponnding CD player.
Also DVD players tend to assume that you're going to use the s/pdif output.
They'll have d/a for audio output jacks, but they are usually of low
quality and are geared for the population who have only $200 to spend
on amp and speakers, or who run it into their tv and use the tv speakers.
If you have a quality surround sound preamp, then using the s/pdif output
is the way to go. No cable distortion.
