Audio Forums
Reply
Thread Tools Display Modes
Cubase 3 & Delta Audiophile DMA Buffer
toneho
Guest
Posts: n/a
      06-27-2005, 11:37 PM
Howdy - I'm using Cubase SX 3, and have come across an odd problem. I
can use my Delta Audiophile 2496 with DMA Buffer Size (Latency)
settings up to and including 768 samples. However, if I increase it to
896 samples, I either can't start Cubase or if I can, Cubase
automatically selects the default ASIO Multimedia driver and won't let
me switch back to the Delta driver. I can use a DMA Buffer Size of
1024 samples, though.
Any help is appreciated. Thanks.
Laurence Payne
Guest
Posts: n/a
      06-28-2005, 10:16 PM
On Tue, 28 Jun 2005 21:46:38 GMT, (E-Mail Removed) (Aphelion)
>Sounds like a fault with the Delta drivers, do you have any other ASIO
>application with which to check the 896 buffer setting?
>If other ASIO apps have problems, the ball is in M-Audio's court.
Same here. I have Delta 1010, essentially the same driver as the
Audiophile. 768 samples DMA buffer seems unacceptable to SX3.
Cubase 5, Wavelab and other applications don't mind it.
CubaseFAQ www.laurencepayne.co.uk/CubaseFAQ.htm
"Possibly the world's least impressive web site": George Perfect
timur-san timur-san is offline
Junior Member
      03-13-2010, 12:33 PM
Hi there,
...same problem
However, setting up m-audio's dma buffer to 1024 samples instead of 896 seems make it in Cubase SX3.
What's funny about is is that m-audio tells me I get 10 msecs latency on 1024, and 11 on 896 (I use 96000 sample rate).
peace
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
2 Delta 1010's in Cubase - help needed telltaleaudio Pro Audio 0 05-20-2007 07:36 AM
configuration of two delta 1010 lt with cubase 2. musikfritze Cubase 0 03-01-2005 09:24 PM
Audiophile 2496 and Delta 1010LT Self Cakewalk 4 01-07-2005 07:31 PM
Record problem:M-Audio Delta Audiophile 24/96 Per Erik Baro Cubase 8 12-23-2004 12:23 AM
Is M-Audio Delta-44 much beeter than USB Audiophile 2496 chowdhury Pro Audio 2 07-19-2004 12:35 PM
