Audio Forums
Reply
Thread Tools Display Modes
Cubase - Mac and Snow Leopard
Danny T
Guest
Posts: n/a
      02-11-2010, 04:53 PM
I've been gone for a while. Is cubase running right on Snow Leopard
now? If so, is it worth the upgrade?
Thanks
Danny T
Guest
Posts: n/a
      02-12-2010, 03:37 PM
> > Thanks
> Cubase Studio 4 seems to run quite well on SL. Note that I use very
> little MIDI, mostly just live capture and editing.
> I upgraded to SL from 10.5 w/o re-installing CS4 and all seems well so
> far.
> Good luck!
> JB
> The heat from below can burn your eyes out!!
Thanks for the vote. I went sailing for 6 months and soft of got lost
from the tech thing.... I do capture too - no midi at all.
Have a great day
http://www.dannytaddei.com
John Albert
Guest
Posts: n/a
      02-16-2010, 04:28 AM
RE:
"I've been gone for a while. Is cubase running right on Snow
Leopard now? "
I've been using Cubase LE4 with Snow Leopard since it came
out, without problems. It's worked fine with 10.6, 10.6.1,
and 10.6.2.
I previously was using OS 10.4.11, no problems there, either.
- John
Danny T
Guest
Posts: n/a
      02-18-2010, 10:31 PM
On Feb 15, 11:28*pm, John Albert <j.alb...@snet.net> wrote:
> RE:
> Leopard now? "
> and 10.6.2.
> - John
I just ordered snow leopard..... Thanks
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
UX256 8 Port USB Midi Interface and OSX Leopard? Jamie Kahn Genet MIDI 12 06-13-2008 06:03 AM
Anyone know if Tascam will update the US428 driver for Leopard? Danny T Cubase 2 12-15-2007 05:42 AM
hi, Im needing a snow blower of sorts gigabyte409@gmail.com Cakewalk 1 11-17-2007 03:36 AM
Pro Tools and Leopard fleemo17@comcast.net Pro Audio 0 10-29-2007 09:06 PM
Digital Performer 5 Leopard compatible? frankcoffman@comcast.net Pro Audio 4 10-17-2007 03:53 PM
