On Tue, 2 Mar 2010 06:13:26 -0800, Cheesehead wrote
(in article <(E-Mail Removed)>):
> On Mar 1, 9:50=A0pm, "Arny Krueger" <ar...@hotpop.com> wrote:
>> "Cheesehead" <dplotusno...@yahoo.com> wrote in message
>> news:(E-Mail Removed)
>>> When I use it in equalized mode there is no hum. =A0But the
>>> output level is too low.
>> Too low for what?
>> How much is it too low?
>>> So I switched mode and connected it to the phono input.
>>> Now the level is right but there is a clear hum.
>> The equalized output of this inexpensive turntable =A0 is not designed fo=
> r
>> connection to a phono input.
>> Phono inputs are basically massive bass boosters, so of course any hum wi=
> ll
>> be magnified.
>>> I checked the power line and nothing is plugged in
>>> backward.
>>> Anyone have a fix?
>> You need something with a more sensitive, but unequalized input.
>> Check this source out, under "boosters"
>> http://www.phonopreamps.com/
> I guess I considered this a quality mid-range turntable rather than an
> inexpensive unit. It's not like it's a BSR or BIC.
What we really need to know about before anyone can be of much help is what
kind (brand and model) of phono cartridge you have. If it's a moving-magnet
type (MM) (or moving-iron) type, then you need to use the phono input because
these cartridges are purposely rather low output compared to the other,
so-called, "line-level" inputs designed for CD decks, tuners, tape players,
etc. If it's a crystal or ceramic cartridge (which I doubt-haven't seen one
of those for decades), then it would go into one of the line inputs and not
the phono input.
> By the output level being "too low" I mean that it (a) mismatches
> other components and therefore (b) does not allow a good CD burn on my
> Philips CD unit.
Magnetic cartridges have low outputs in relation to other components. That's
why the phono input is marked for phono only. When you plug the turntable
into the phono inputs on your amp/receiver, do you have to turn the volume up
real high in order to hear it? Is that when you get hum? IOW, does it hum
when you turn the volume to same setting on the control that gives you decent
volume and NO HUM with other components (FM, CD, Tape)?
If the answer is yes, you do have to turn the volume control up inordinately
high to get decent volume, then you might have a moving-coil (MC) cartridge.
If this is the case, your phono input probably doesn't have enough gain.
Telling us the make and model of the cartridge you are using, should give us
that information
> I'm going to give it a look-over to see if there is a place where I
> can find a place to attach a ground wire.
> And thanks for the link. Perhaps a quality pre-amp is all I really
> need..
It's possible, BUT, unless you happen to have a low-output moving-coil, it's
probably NOT your problem. With most MM or Variable Reluctance cartridges,
the built-in phono stage in your receiver or amplifier should be more than
sufficient. If you get plenty of output from your cartridge and sufficient
gain from your phono stage to give you decent volume at normal volume control
settings, then the problem you have is a grounding issue and most likely a
new phono stage would hum just as badly as the one you have now. In most
situations, you MUST have a grounding wire that goes from the tone-arm
mounting base itself to the grounding lug (usually that's a finger-screw)
located near the phono inputs on the back of your receiver/amplifier. That's
likely the problem with your hum. But really, I need more info before I can
say anything for sure.
