Audio Forums
Reply
Thread Tools Display Modes
How Do We Transfer Cassette Tapes to CDs?
Jack Bruss
Guest
Posts: n/a
      07-03-2004, 04:16 PM
My wife is a singer, and she wants to take some of her old cassette tapes
and move the songs to CDs, and we don't know how to go about that. She has
purchased Pyro 2004, which hopefully handles the software part of it, but
how do we go from the tape player, which has phono jacks to the sound card,
which doesn't? The salesman at Best Buy sold my wife a $40 set of cables,
but they are phone jack only, so can't be used unless I get an adaptar of
some sort, I guess.
Any advice would be appreciated.
Thanks,
Jack
Stratomaster
Guest
Posts: n/a
      07-03-2004, 06:22 PM
> some sort, I guess.
> Thanks,
> Jack
The cable you need has a 1/8" stereo phone plug on one end, and two RCA
plugs on the other. You would then connect the phone plug into the line
in of your sound card.
I don't know enough about Pyro to tell you whether it will record from
the line in. If not, you can download a pretty good free program at
http://audacity.sourceforge.net/
Whatever program you use, make sure you record in the .wav format and
not .mp3. That way, you'll get the best quality.
Jeff Sandys
Guest
Posts: n/a
      07-06-2004, 04:07 PM
You can get a cable with two rca phono jacks for the tape unit
and a 1/8 stereo plug jack on the sound card. Best Buy should
take the cable you bought back and get you the correct one.
Does Pyro record from the line in? You might consider a software
package like Steinberg's Clean that will record the analog audio
from tape, eliminate some of the hiss, normalize the sound level,
and break it into 'songs' according to the silence gaps or where
you want the breaks, then burn an audio cd. Clean was designed
to convert tapes and LPs into audio CDs. I only paid $10 for
Clean when it was on sale at Guitar Center.
With digital recording you don't want to saturate the input, you
never want to go into the red. Unlike analog recording where there
is some headroom for minor excursion above 0db, digital recording
recording is unforgiving when you go above 0db, it like truncates
the numbers, makes it sound awful. So you want to record safely
down at -3 to -6db. But if you burn an audio cd at this level it
will be quiet compared to your other cds. What normalizing will
do is find the peak in the recording, raise that 0db and raise the
rest of the song by the same amount.
Thanks,
Jeff Sandys
> some sort, I guess.
> Thanks,
> Jack
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Cassette to CD transfer question scottcavenaugh@lycos.com Audio Equipment 2 01-24-2007 03:20 PM
Transfer of 4-track Tascam 234 Syncassette tapes? David Abrahams Pro Audio 2 11-08-2004 08:58 PM
cassette to cdr transfer... sample rate problem perhaps? joem Pro Audio 0 07-16-2003 06:42 AM
cassette to pc transfer Simon Pro Audio 5 07-04-2003 02:14 PM
Re: cassette to pc transfer Mike Rivers Pro Audio 0 07-03-2003 07:21 PM
