On Sun, 30 Oct 2005 04:44:02 GMT, Richy <(E-Mail Removed)>
wrote:
>I'm considering the M-Audio Audiophile 2496. It has 1x1 MIDI I/O so
>that's 16 channels right? Does that mean I will be limited to only 16
>channels of MIDI in all my software applications?
The Audiophile has one MIDI port for connecting external devices. One
port supports 16 channels. So if you want more than this, you'll
need to install a further physical MIDI interface.
If you install software synths on your computer, each sets up its own
internal MIDI port, allowing it to talk to your sequencer directly on
(up to) 16 channels. So the physical MIDI port on your soundcard
doesn't enter the picture.
Your sequencer will see a choice of MIDI outputs. One will be the
physical port. The others will be your installed softsynths. Each
will potentially support 16 channels, though a particular softsynth
may actually use fewer.
CubaseFAQ
www.laurencepayne.co.uk/CubaseFAQ.htm
"Possibly the world's least impressive web site": George Perfect
