Audio Forums
Reply
Thread Tools Display Modes
Finalizing recordings in Cubase
XODDI
Guest
Posts: n/a
      11-13-2010, 11:07 PM
Basically, I've EQing the tracks, doing the final levels and then
export them as a .wav file and removing any DC offset and normalizing
them, finished. It just occurred to me that this is probably not
optimium.
Yes, I know I am a ****ing savage.
So, use any specific plug-ins on the main? Render options?
TIA
yer pal
XODDI
Jos Geluk
Guest
Posts: n/a
      11-14-2010, 12:54 AM
> optimium.
I use a multiband compressor and a bit of maximizing on the final mix. A
little of both goes a long way, usually.
Jos.
Ardis Park Music
www.ardispark.nl
Paulo Gomes
Guest
Posts: n/a
      11-14-2010, 09:09 PM
There's no rules, but there are some common procedures.
After the mix, I export the file and import it on Wavelab
Most of the times I put a multiband equalizer, a multi band compressor and
multiband maximizer. Sometimes if needed I put an harmonic exciter and a
stereo enhancer... These last 2 have to be used carefuly.
Unlike you, I don't normalize but like you, I remove DC offset.
I always leave 2 seconds of silence in the begining.
As for Eqs, Compressors and maximizer, I don't have any rules, it goes how I
hear it.
Respect
Paulo
"XODDI" <(E-Mail Removed)> wrote in message
news:7044a4a3-4e2b-403f-a752-(E-Mail Removed)...
> optimium.
> TIA
> yer pal
> XODDI
Danny T
Guest
Posts: n/a
      11-15-2010, 01:20 AM
On Nov 14, 3:09*pm, "Paulo Gomes" <paulo.alb.REMOVE.go...@netcabo.pt>
> hear it.
> Respect
> Paulo
> "XODDI" <sirstudlyspanksa...@gmail.com> wrote in message
> > optimium.
> > TIA
> > yer pal
> > XODDI
Multi compressors, loudness maximizers and even exciters all work
towards no dynamics. Be careful. See this: http://www.turnmeup.org/
Paulo Gomes
Guest
Posts: n/a
      11-15-2010, 11:50 AM
You're absolutely right... One gotta be carefull using those processors
other wise it might sound dead.
Paulo
XODDI
Guest
Posts: n/a
      11-15-2010, 07:05 PM
On Nov 15, 6:50*am, "Paulo Gomes" <paulo.alb.REMOVE.go...@netcabo.pt>
> Paulo
> towards no dynamics. Be careful. See this:http://www.turnmeup.org/
Jos, Paulo, Danny, thanks for the tips. I have always kept compressors
off the mains, almost superstitiously.
But what about the UV22 Apogee dithering plug-in?
Danny T
Guest
Posts: n/a
      11-15-2010, 07:57 PM
> > Paulo
People say they can hear the difference but I can't so I leave it
alone.
As for keeping compression off the mains, that is not an issue. You
can compress the mains with stellar results, just don't over
compress.
Keep in mind a few things to look for. Audio, when compressed wrong
not only loses dynamics but makes a pumping sound. You might want that
for some things. You'll hear it if you are thinking about looking for
it.
If you compress everything just a little, you can bring out dynamics
too. When you have a guitar miked up close, you'll see that some
things really get accentuated. A compressor can level it out and make
it sound much more natural but only when used lightly. I like to
compress an acoustic that I'm figure style on with about 2:1 or maybe
2.5 :1. That brings up the quite stuff and mellows the over picked
notes. I do about the same to my vocals. I usually compress the hell
out of the bass at about 6:1 so that it is just a solid backbone. I do
something similar to snare and kick but I leave the toms a lot more
loose. Back ground vocals I compress the hell out of too so that they
are not the dynamic for people to pay attention to, leaving the lead
vocal as the main actor. .. usually good....
In the end when everything has the flavor that fits into the pie just
right, I often compress the entire mix by about 1.5:1 to 2:1. that
brings everything into the same room so to speak.
Having said all that, I do natural sounding music where as in a dance
song none of that applies. I am not into dance/trance/house...
whatever. I do more of an acoustic style. When you are going for
effects, nothing but creativity applies. The over squashed sound might
be fine and dynamics can be achieved by removing instruments for a few
bars. That sort of non intelligent mood music needs to grab your body,
not your brain. No I don't like it but I do understand it....
Good luck - make lots of music
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Finalizing a CD Tom Penharston Pro Audio 6 01-09-2005 12:00 AM
Re: "DSD recordings good. PCM recordings bad." - Dr. Diamond Codifus High End Audio 128 02-08-2004 06:20 PM
"DSD recordings good. PCM recordings bad." - Dr. Diamond langvid High End Audio 2 01-27-2004 05:59 PM
Why don't classical piano recordings sound as good as pop recordings? Brian Patterson High End Audio 10 01-09-2004 04:12 AM
"finalizing" for voiceover...Gear/software opinion?? markC Pro Audio 2 07-22-2003 05:33 AM
