"Danny T":
> I've used cubase since about version 2 but I haven't ever dealt with
> ivst's or samplers. I always just use cubase to capture what I play or
> someone else's playing.
> OK, I was to branch out a bit. I have the sound set 1 for Halion that
> was free and I started messing with it. I'm a little impressed with
> what I can do with my midi drum set and the sounds there. I'd like to
> try out more things, especially piano and keyboard sound libraries but
> also everything else.
> Where do I look, what is good and what should I have to pay? Also, if
> there are any free libraries, I'd like to start there first.
> Thanks for the help - I'm a total newbie on this stuff
Native Instruments has 2 free VSTi plug-ins, which also have stand-alone
versions besides the plug-in versions. As you seem to be a piano/keyboard
player/performer, this might come in handy for you, if you only want the
sounds "live", but donīt need a sequencer host software taking up
resources... ;-)
The first one is called "Kore Player" and the second one "Kontakt Player".
Both are available free and at least KorePlayer includes a sound set. In
addition to that, free sound sets can be downloaded separately! Of course,
you can also buy more sound sets, but there should be something usable in
the free ones.
NOTE: you need to register with NI to request the download links!
http://www.native-instruments.com/#/...earch=freeware
It should at least be a good place for a start. If you donīt like the sounds
in the free packages or canīt really use them for your purposes, you havenīt
lost money, but only some time...
Good luck and fun!
Phil
