Audio Forums
Reply
Thread Tools Display Modes
HELP! Recording LPs to Computer
Donnie
Guest
Posts: n/a
      04-03-2005, 08:30 PM
Okay, I'm pretty useless at this sort of thing, but I have dozens of
LPs (Is that called "Vinyl" now?) that I want to record to my Windows
XP computer and thence to CD.
My "Stereogram" is a Sony and is about thirty five years old. It's an
HMP - 40 Stereo Music system but it still plays superbly.
I've tried putting Red and White cables in all the usual places and
putting the little round thing in all the holes in the back of the
Dell.
Nothing seems to work. It has a DIN socket, whatever that is, but I
don't have a lead (wire) for that.
I'm using RIP Vinyl which works but not as a Line In.
Any suggestions?
TIA
Donnie.
Steve Urbach
Guest
Posts: n/a
      04-03-2005, 09:04 PM
On Sun, 03 Apr 2005 21:30:49 +0100, Donnie <(E-Mail Removed)>
>Dell.
>Any suggestions?
>TIA
>Donnie.
Line in on your Dell (blue), you need a RCA to mini phone plug cable.
Connect the RCA end to "tape out/line out" on your Sony.
You should be able to open your Dells Volume Control and Play the
sound from the Sony as a test.
You will need some sort of recording software to deal with the big
files (300-400Meg) recording a LP can make.
I use Polderbits Sound Recorder/Editor from www.polderbits.com. It is
Trialware and was easy to use, has click anf scratch filters.
, _
, | \ MKA: Steve Urbach
, | )erek No JUNK in my email please
, ____|_/ragonsclaw (E-Mail Removed)
, / / / Running United Devices "Cure For Cancer" Project 24/7 Have you helped? http://www.grid.org
Donnie
Guest
Posts: n/a
      04-03-2005, 09:18 PM
On Sun, 03 Apr 2005 21:04:14 GMT, Steve Urbach
>>Dell.
>>Any suggestions?
>>TIA
>>Donnie.
>, _
Hey Steve thanks. It'll probably be next weekend now but I'll post the
results.
Thanks again
Donnie
Guest
Posts: n/a
      04-03-2005, 09:32 PM
On Sun, 3 Apr 2005 14:23:11 -0700, "Julian Adamaitis"
>"Steve Urbach" <(E-Mail Removed)> wrote in message
>news(E-Mail Removed).. .
>Donnie,
>What has a DIN socket? You don't have an RCA jack labeled "tape in",
>"record out", or "line out" as mentioned below?????
I might have but it's dark under the table this thing is on. I have
looked in all seriousness but these terms are all Japanese to me.
(Well it's a Sony right <g>)
IS your Sony a European
>model?
Please don't shout at me <sob> I'm ignorant <g>
Sorry, the Sony has a DIN socket and yes it's English.
I'm not sure what an RCA Jack is but I have to be at work at 06.00
tomorrow so I'm going bye bye now.
Let's just pretend that I'm like TOTALLY stupid, and therefore where
might I obtain such a cable/wire/thingy?
I live near Birmingham, United Kingdom.
>Another good freeware is Audacity:
Many thanks.
>http://audacity.sourceforge.net/
>Julian
Again to both of you, many thanks. A wonderful place is the Internet.
Steve Urbach
Guest
Posts: n/a
      04-04-2005, 01:42 AM
On Sun, 03 Apr 2005 22:32:09 +0100, Donnie <(E-Mail Removed)>
Hey my Sony TC165 has a DIN (I bought it at the PX in Germany).
Mine has a small switch near that says Rec/PB <-> Aux
Put it in Aux and use the Line out Jacks. DIN is easy to plug into
between DIN devices, but the cross talk is bad, the levels lower and
you would need a DIN to Mini-phone plugs cable.
Now days the are those Red and White plugs that look like a cheap tiny
crown with a prong out the middle.
Mini phone plug looks just like you Walkman (portabl player)
headphones have.
Any Electronics store. These are *really* common.
, _
Donnie
Guest
Posts: n/a
      04-04-2005, 07:22 PM
On Mon, 04 Apr 2005 01:42:20 GMT, Steve Urbach
>headphones have.
>, _
Gotcha - I now recognise those tiny crown things, and will put on my
stupoid act (comes so easily) in my local electronics store.
Thanks again. Really, THANKS.
Stay tuned for results..
PS Note I haven't even touched recording sound off my VCR yet <g>.
Steve Urbach
Guest
Posts: n/a
      04-04-2005, 08:50 PM
On Mon, 04 Apr 2005 20:22:25 +0100, Donnie <(E-Mail Removed)>
Same connector for most Stereo VCR. Use only one connector for Mono
(leave the other hanging and turn off the unused input when recording
Mono on the PC.
, _
Donnie
Guest
Posts: n/a
      04-07-2005, 08:46 PM
>Donnie,
>"record out", or "line out" as mentioned below????? IS your Sony a European
>model?
>Julian
I just downloaded Audacity* and jerry rigged input from my Headphone
socket in the Sony to the Line In in the dell. So I got a brief
recording.
I've saved the Test 1 in XP but can't quickly figure out how to burn
it to a CD.
Where please should I be looking? (I was contemplating Windows Media
Player???)
PS Don't worry, I'm buying the proper kit (red and black pointy wire
things that plug into my sony and then my dell Line in.)
*Very easy to record from btw, thanks again.
Donnie
Guest
Posts: n/a
      04-08-2005, 06:47 PM
On Fri, 8 Apr 2005 12:00:19 -0500, "Dan K"
>"Donnie" <(E-Mail Removed)> wrote in message
>news:(E-Mail Removed).. .
>> >Donnie,
>European
>> >model?
>> >Julian
>> recording.
>> it to a CD.
>> Player???)
>You should be getting wave files (.wav) out of Audacity. Most CD burner
>software can take these files and make an audio cd out of them.
>If you plan on doing anything else with these files (like playing them on
>your PC) I would suggest converting them to mp3 files as you get about a
>10:1 compression which will save you A LOT of disk space. I use freeware
>cdtomp3freeware which works great.
>Under NO circumstance would I ever use Windows Media Player again. Their
>rev 9 version has a HORRIBLE clipping problem that can blow speakers. It
>may have been fixed in rev 10, but I'm not going to try it to find out. Use
>Winamp...works great.
>If you need to go the other direction to get wave files from an audio CD, or
>need to copy an audio CD, I would suggest EAC (exact audio copy) as it will
>let you know if it has problems reading the master CD. Other CD s/w can
>complete properly when there have been errors and you won't know it until
>you listen to your copy.
>Dan
How do you rate RIP Vinyl?
Thanks for the above but very rushed for time now and longer reply
later.
Donnie
Guest
Posts: n/a
      04-09-2005, 08:10 PM
HEY!!!
It woirks !
Those cables and those little red and , umm whatever the other colour
was are all over the place y'know <g>.
I managed to record a half an LP of Crosby Stills and Nash and then
burn it onto a CD and it didn't sound half bad.
Now to perfection !!!!
(Pity there's no way to speed up the playing of an LP. 90 minutes is
still 90 minutes even these days).
My grateful thanks to all "above" who have advised me.
<Sigh> now I have to apply for a job instead of burning my favourite
bits of films (movies to you guys).
Thanks
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Recording my old lps and tapes into Pro tools in real time nectarlove@gmail.com Pro Audio 5 09-08-2006 12:05 PM
Recording cassettes and LPs to computer swangdb Pro Audio 8 04-30-2006 12:12 PM
HELP Recording LPs to CD Donnie Audio Equipment 1 04-29-2005 09:56 AM
Pro-ject Tube Box VS. Musical Fidelity X-LPS Igor High End Audio 1 02-22-2004 05:15 PM
What's wrong with cleaning LPs using tap water S. S. High End Audio 12 02-09-2004 02:21 AM
