Audio Forums
Reply
Thread Tools Display Modes
Interesting article from recording equipment designers about todays DACs and OP-Amps
Sonnova
Guest
Posts: n/a
      02-26-2009, 03:30 PM
Here is an interesting insight into how pro designers see op-amps vs discrete
component gain stages and modern DACs/ADCs. Many seem to think that discrete
circuitry still has the edge over IC's and that all DACs are not created
equal.
For instance, John La Grou, Founder of Millennia Music & Media Systems
(makers of mid-to-high-end recording electronics) had this to say about DACs
and ADCs:
"Itšs all about sound. A converteršs specification is rarely an indication of
how it sounds. I always suggest that engineers take spec sheets with a grain
of salt. Rather, they should ALWAYS compare ADCs and DACs (or any audio
product for that matter) in real-world A-B listening tests before making a
buying decision."
Read the rest of the discussion about today's pro audio semiconductor
products at:
http://www.nxtbook.com/nxtbooks/newbay/prosound_200902/
Page 39 and 40 and for more info:
http://www.prosoundnews.com/article/20024
Sonnova
jwvm@umich.edu
Guest
Posts: n/a
      02-28-2009, 07:02 PM
> equal.
> and ADCs:
> buying decision."
Indeed A-B tests are the ultimate means of comparison but only if done
correctly to avoid bias errors. There is little reason to believe that
even audio engineers are immune to bias and can discern extremely
small quality differences by simple comparisons. To say that specs
don't matter is only true because just about any state-of-the-art
converter will have inaudible and imperceptible artifacts if used in
an intelligent manner. Other factors can affect chip performance
including PC board layout requirements and noise sensitivity that play
an important role in part selection, however.
Some of these designers may also be guilty of bias against analog
integrated circuits. There should be little need for discrete
transistors in most cases except perhaps for very low noise circuits
like microphone preamplifiers.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Question about pre-emphasis in SPDIF Kevin Pro Audio 15 01-27-2013 01:59 AM
Please Information Sound Designers Human Noise and Dummies polina Pro Audio 6 02-18-2008 05:34 PM
Are vintage DACs a bargain? andy High End Audio 33 07-18-2004 03:03 AM
DACS Micamp Microphone Preamp Tim Terral Pro Audio 3 08-15-2003 03:35 PM
