Audio Forums
Reply
Thread Tools Display Modes
Re: Maximum length of hifi speaker cable?
Guest
Posts: n/a
      06-24-2003, 05:39 PM
Hi all!
I have done it! Believe it or not I actually used 2 core mains cable!!! It
provided the adequate diameter wire...and it all sounds great! Please don't
all start syaing that I should have used something else 'cos it's all in
palce (cable clips and everything). Anyway, thanks all for your
advice....I'm happy now!
P.S. Sorry Warren! I read your reply just a little too late! Anyway...I am
not an audio expert and it all sounds OK to me so it will just have to do!
Jamie
"Warren Marshall" <wmarsha1 @ bigpond.net.au> wrote in message
newsCCJa.900$(E-Mail Removed)...
> Here's a dissenting view.
> When I used solid-core mains cable as speaker wire, I found that short
runs
> sounded great but longer runs (e.g. 5 metres) had noticeable loss of
treble,
> even for my middle-aged ears! Long runs, even short runs, of thick
> multi-strand cable do a lot of damage to sound reproduction. I don't know
> why, but I know they do. I don't have magic ears - I'm quite happy to
admit
> when a cheaper cable sounds better than a more expensive one. But there is
a
> BIG audible difference between solid core cables and multi-strand cables.
> I use a spectacular cable, which takes a bit of effort but is not at all
> expensive. I buy solid-core Cat-5e network cable, 3 times the length of
> Cat-5w for the length of speaker cable I'm making.
> So you would require 6 x 12 metre lengths of Cat-5e for 2 x 12 metre runs.
> Simply plait 3 lengths together, like girls plait their hair (ask your
wife
> or girlfriend if you need a lesson). At each end, seperate all the solid
> colours from the stripe colours, and join the solid colours together as
your
> + (after stripping the wire ends) and the stripes together as your -. This
> cable is about 13 guage which is enough copper to offer low resistance,
but
> has virtually no impedence, because the cable is in a twisted pair
> configuration, and no "skin effect" which is the capacitative effect
caused
> by the phenomenon that almost all electric current travels within about
> 0.25mm of the skin of a conducting cable.
> So, the bottom line is that you can create your own 2 x 12m super-cable
for
> maybe US$50! Sorry to any esoteric cable manufacturers out there.
> Regards,
> Warren Marshall
> Sydney, Australia
> <(E-Mail Removed)> wrote in message
> news:(E-Mail Removed)...
> > Hi, I know very little about hifi systems apart from the fact that long
> runs
> > of speaker cable should be avoided. I am installing speakers for my hifi
> and
> > need a run of 12 metres (approx. 36 feet) for one speaker and 7 metres
> > (approx. 21 feet) for the other speaker! I know this is very long but
> > there's nothing I can do about it. What do you reckon? Will my sound
> quality
> > be noticably worse to an amateurs ears? I will not be spending silly
money
> > on expensive speaker cable either....just standard off the shelf stuff.
> Any
> > opinions or advice appreciated.
> > Regards
> > Jamie
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
usb dac - length of cable rhett.morson@gmail.com High End Audio 12 07-26-2008 03:38 PM
Cable Length rcs3 High End Audio 12 07-28-2006 09:24 PM
Cable length = pro gig Carey Carlan Pro Audio 4 11-24-2004 05:39 AM
Maximum Length for Toslink and Firewire Cables Cary Pro Audio 8 06-25-2004 03:34 PM
Cable length Gregory Lee Pro Audio 2 11-05-2003 09:38 AM
