On Oct 15, 2:38=A0pm, August Karlstrom <fusionf...@gmail.com> wrote:
> I have read more than one article where the
> recommended maximum length of loudspeaker
> wire is presented as a function of the wire gauge and
> the impedance of the speakers, e.g. in the Wikipedia
> article
> http://en.wikipedia.org/wiki/Speaker_wire#Wire_gauge
> I have also heard that output power and damping factor
> should be considered as well - a high power amplifier
> needs a thicker cable.
> Are there any studies made about the wire length
> contra output power and damping factor?
First, ignore most if not all claims you see about
damping factor. It's a feel-good specification that
except in the most pathological cases, has essentially
no meaning whatsoever, despite the occasional
protestations you see to the contrary.
Second, check out:
www.cartchunk.org/audiotopics
and click on the link labeled "Damping Factor:
Effects on System Response," for the reason why
damping factor is a useless measure.
As to the fact that bigger amplifiers need heavier
wire, while this may be true when you're buying
extension cords to run power equipment and effects
such as ohmic losses and heating in a 100-foot
cable and resulting the voltage drop at 25 or 30 or
more amps IS significant, 25 or 30 amps into
an 8 ohm speaker correspond to 5000 to 7200
watts. Hardly a situation even remotely possible in
a home high fidelity system.
By the way, the ultimate limit, as defined by the
fusing current, i.e., the temperature at which the
wire fails due to excessive temperature (it melts),
for 14 gauge copper is listed as 140 amperes. Into
an 8-ohm speaker, that represents 156,800 watts.
In other words, for PRACTICAL application, no,
higher power amps DO NOT require thicker cables
once you get below the 16-gauge realm.
For runs up to 25 feet, any good quality 14-gauge
speaker wire quite appropriate. 14 gauge copper
twin-lead speaker cable has an effective DC
resistance of about 0.005 ohms per foot. 25 feet
gives you a total resistance of 0.125. If you have
already read the articale I cited above, you would
know' that for a typical 8-ohm speaker, this lowers
the electrical damping of the system by a measely
2%: having far less an effect on your speaker's
response than changing humidity temperature or,
for that matter, slight movements of your head
when listening.
The comments in the Wiki article suggesting that
silver has a lower resistance than copper, while
true, are simply irrelevant. Yes, a 14 gauge silver
cable 25 feet long will have a total resistance of
0.118 ohms vs 0.125 ohms for copper: that's less
than a 10% difference. FOr a price FAR lower than
upgrading from 14 gauge copper to 14 gauge silver
wire, you can upgrade, if you really think it's
important from 14 gauge copper to 12 gauge
copper and drop the total resistance not by
a mere 9%, but by nearly 40%. That drop will,
by the way, change the loss of electrical damping'
on the speaker from 2% down to about 1.3%. Big
deal.
[Again, posting from google waiting for my nntp
server to come back on line]
+ Dick Pierce |
+ Professional Audio Development |
