Audio Forums
Reply
Thread Tools Display Modes
Microphone Connection Advice Wanted
David Angelovich
Guest
Posts: n/a
      02-15-2005, 08:41 AM
Hi
I've bought a Shure SM58 microphone, which I need to connect to a 6.5mm
and 3.5mm plug (obviously not at the same time...)
I'm not sure what's needed to convert it's XLR plug to 6.5mm
I can get an adapter from Streetwise (www.streetwise.com.au)
- It's described as: "Unbalanced signal converter with an XLR socket to
a 6.35mm stereo plug. Features a heavy duty construction and gold
plating which ensures better conductivity and longer life."
http://www.streetwise.com.au/product...oducts_id=2927
I'm not sure what the unbalanced bit means... Can someone explain? I
can't find anything understandable on Google.
Is there a different solution I can use... that isn't all that
expensive. (At the moment, it's kinda just a toy.... so I don't need
great quality right now.)
Thanks,
David Angelovich
Philip N. Daly
Guest
Posts: n/a
      02-15-2005, 05:05 PM
You didn't say what your application was. Are you trying to plug this
thing diectly into a sound card or an amplifier?
The XLR is a balanced connector because it uses 3 wires not 2. In the
end it just means that you can use a longer cable run without too much
noise.
Again, you need to say what you're trying to do. Good luck.
David Angelovich
Guest
Posts: n/a
      02-15-2005, 08:04 PM
"Philip N. Daly" <(E-Mail Removed)> wrote in message
news:cuta4j$12us$(E-Mail Removed)...
>> - It's described as: "Unbalanced signal converter with an XLR socket to a
>> 6.35mm stereo plug. Features a heavy duty construction and gold plating
> noise.
>> Is there a different solution I can use... that isn't all that expensive.
>> (At the moment, it's kinda just a toy.... so I don't need great quality
>> right now.)
I'm going to be using it with a sound card, and possibly with an amp....
It's mostly for voiceover-type stuff...
Philip N. Daly
Guest
Posts: n/a
      02-15-2005, 09:43 PM
>>>right now.)
Generally speaking, plugging a good mic into a sound card isn't a great
idea unless you've paid a *LOT* for the card? You'll probably need a
microphone pre-amp ...
P
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Microphone-preamp-recorder connection question Paul Pro Audio 5 08-28-2006 07:25 PM
microphone/guitar connection through Edirol UA20 to Cubase SX dave Cubase 2 09-23-2005 08:01 PM
Serial connection of two ways baffle, need advice Slim Pro Audio 0 05-19-2005 08:02 PM
MOTU828II & ADA8000 connection advice Eddie Cooper Pro Audio 2 09-01-2004 04:12 PM
Wanted!!! NY based Photographers Videographers Webmasters+3D Animators Modelers Wanted!!! Joe Donut Pro Audio 0 12-06-2003 12:50 AM
