Audio Forums
Reply
Thread Tools Display Modes
Need powercord for soundcraft mixer
jim
Guest
Posts: n/a
      02-12-2004, 06:54 PM
Thanks for taking note. The mixer is a Soundcraft spirit folio FX8
and the power supply and cord is the same as the SX12. The end that
plugs into the mixer is what I need. This is a problem on all these
mixers - you have to buy a complete power supply. There are 3 wires
and they can be soldered inside the power module. The plug is
rectangular about 5/16"x1/4". Its a cheap setup on an otherwize
quality mixer and yes it falls out too easily. My cord works but the
plug is damaged. If anyone out there has a bad power supply with a
good plug - I need it. I'll pay $15 ??????? for this cord.
952866 is the part number on the power supply. Be sure to email me
directly at:
http://www.audio-forums.com/(E-Mail Removed)
thanks Jim
JIM SCHMIDT
4480 N. ACADEMY Ave.
SANGER, CA 93657
ph./fax (559) 875-0659
me
Guest
Posts: n/a
      02-12-2004, 07:34 PM
They ALL crap out at this point, and Soundcraft want a fortune for the
PSUs. I hard wire them (yep, I know its a suboptimal solution) or if
the client absolutely insists on a removable PSU, I replace both plug
and socket with something better (XLR4M chassis and XLR4F cord IIRC).
M
Stephen Blakeney
Guest
Posts: n/a
      02-15-2004, 04:11 AM
>directly at:
>(E-Mail Removed)
>thanks Jim
>JIM SCHMIDT
>SANGER, CA 93657
I have an FX8 and am very unimpressed with the wallwart connector
((although I haven't had a problem yet). Seems way shaky, very loose
for a good solid connection. But it works so far. We'll see. Haven't
checked to see what Soundcraft wants for a replacement. Hope I never
need to.
SWB
jim
Guest
Posts: n/a
      02-15-2004, 06:16 PM
Please tell me where i can get the (XLR4M chassis and XLR4F cord
IIRC)you mentioned. Is this a better option than molex connectors?
Jim
> M
Mike Rivers
Guest
Posts: n/a
      02-16-2004, 04:42 PM
In article <(E-Mail Removed) > (E-Mail Removed) writes:
Any Switchcraft dealer will have them. Try http://www.markertek.com
Understand, though, that the shape and mounting of an XLR connector is
quite different than what your mixer has right now. You'll have to do
some cutting and drilling in order to mount the XLR into the case. Be
sure that you have enough room to do that before you go looking for a
pair of connectors. Do you know how to open the case and take a look
around? That should be your first step.
I'm really Mike Rivers - ((E-Mail Removed))
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Scott Dorsey
Guest
Posts: n/a
      02-17-2004, 07:14 PM
>IIRC)you mentioned.
Digi-Key stocks them. Markertek video supply has them too.
I can't imagine anything too much worse than Molexes.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
soundcraft series 2 vs soundcraft 1600 wich to use? labpartner Pro Audio 7 10-31-2004 11:32 PM
Need power cord for soundcraft mixer jim Pro Audio 0 02-15-2004 12:57 AM
Need Soundcraft mixer power cord Dan Mills Pro Audio 7 02-12-2004 03:11 AM
Wanted: Recording Mixer (Soundcraft, TAC, Tascam etc.) Jay Latte Pro Audio 1 01-23-2004 08:03 PM
Soundcraft mixer Larry Hoff Pro Audio 0 07-01-2003 10:17 AM
