Audio Forums
Reply
Thread Tools Display Modes
Need RC-D45 Remote for Tascam DA-40
Lovguitar
Guest
Posts: n/a
      03-17-2010, 10:15 PM
My Sony Dat mixdown deck bit the dust and I found a couple of Tascam
DA-40 decks pretty inexpensively in NYC off Craig's list. They both
work fine but neither has the wired remote. Any leads on the RC-D45
remote? I've tried Tascam and Angelfire but no luck. The remote
would make my life much easier!
thanks,
you can hear projects I've been working on with my son at
www.myspace.com/chriscassonemusic/
Scott Dorsey
Guest
Posts: n/a
      03-18-2010, 02:07 PM
In article <d21f3c00-de1f-4251-a9ef-(E-Mail Removed)>,
Check the service manual. I think that the wired remote is just a box
of switches with a connector on the end, and no actual electronics inside.
If that's the case you should be able to build one yourself without too
much trouble, or adapt an old Ampex 350 remote box....
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Lovguitar
Guest
Posts: n/a
      03-19-2010, 02:02 AM
On Mar 18, 7:19*am, Laurence Payne <l...@laurencepayne.co.uk> wrote:
> On Wed, 17 Mar 2010 15:15:40 -0700 (PDT), Lovguitar
> >work fine but neither has the wired remote. *Any leads on the RC-D45
> >remote? *I've tried Tascam and Angelfire but no luck. *The remote
> >thanks,
> >Paul
> While your DAT was working, there was no reason to replace it. *But
> shouldn't you be moving on from an obsolete format now? *It's not as
> if DAT has "analogue magic" or anything :-)
> Presumably you're recording to multitrack analogue tape, else you'd
> have no need for a "mixdown deck"?
Correct. I am recording on a Tascam TSR 8. I have a lot of
previously recorded masters that were recorded to DAT, so I needed a
replacement deck. I also saved my later masters on CDR and on an SD
card using a TASCAM DR1. Other suggestions as to a mastering format?
I want my masters to last a long time. My psychic predicted I will
become really popular in 2054.
Thanks!
Scott Dorsey
Guest
Posts: n/a
      03-19-2010, 01:54 PM
I hate to tell you this, but the only mixdown format that I know of that
I can _guarantee_ will last a long time is 1/4" tape.
DAT is really a mechanical abomination. I use it too, but I also get all
the decks cleaned and aligned every year and I have Eddie Ciletti make sure
they all meet original specs.
--scott
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Need panel speaker placement advice for an odd room Robert Peirce High End Audio 0 12-08-2012 12:32 AM
Need someone for (PAID) remote recording work - HELP RickRyan.com Pro Audio 16 04-17-2006 04:43 PM
FS- 5- Tascam DA-78's and remote yrplace Pro Audio 0 10-29-2005 11:55 PM
Pioneer AV amp need remote HELP Geezer Audio Equipment 1 08-17-2004 07:53 PM
FA: Pair Of Tascam DA-88's,with remote..low reserve! ken Pro Audio 2 01-29-2004 09:56 AM
