Audio Forums
Reply
Thread Tools Display Modes
need receiver
Joe
Guest
Posts: n/a
      02-19-2010, 11:42 PM
I have 2 small Bose speakers- Bose 201 Series IV. I need a receiver so I can
hook them to my TV. I'm looking for a receiver that will serve this purpose
but don't need any special features- just something that will work well with
those speakers for this purpose and will last awhile, so I'm not looking for
junk but a long lasting product.
I really have no clue about this as I haven't bought audio equipment since
the '80s.
I don't even have a clue where to shop.
Suggestions will be appreciated.
Joe
D Wright
Guest
Posts: n/a
      02-20-2010, 03:18 PM
> can hook them to my TV. I'm looking for a receiver that will serve this
> purpose but don't need any special features- just something that will
> work well with those speakers for this purpose and will last awhile, so
> I'm not looking for junk but a long lasting product.
> since the '80s.
> Joe
It all depends on what kind of audio outputs are available on your TV.
If you have a pair of (red and white) RCA phono jacks, you're good to
go. Check your local pawn shops and watch your local Craigslist for a
receiver that has aux and/or tape inputs, and has around 50
watts(plus/minus) speaker output. You can probably find something well
under a hundred dollars.
Be sure to listen to it and hear both left and right channels before you
buy. Do your research before you buy something older than 1980's vintage.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
