Hi folks, long time lurker and midi user but short time Cubase user.
The problem, or solution, is most likely simple and is connected to
project setup. I imported a .wav to add tracks to added an instrument
track using Hyper-Canvas to record a keyboard track.
If I start recording, for example at 8 bars in, the first note
recorded jumps back to the beginning of the track instead of where I
start recording...argg. I can of course slide the completed track but
sometimes some of the first notes are truncated too, but not
always..argg again.
After stumbling through some setup snags with my computer and my
lizard brain, CuBase is running smooth and I can't believe I waited
all these years before I got serious with it.
Thanks all,
Leo Dean, St. Simons Island Georgia
www.leodean.com
