Audio Forums
Reply
Thread Tools Display Modes
Pioneer X-NM1 acting v. strangely
SB
Guest
Posts: n/a
      10-22-2010, 09:31 PM
I have a Pioneer X-NM1. I bought this new in December 2002. It has
been functioning fine up until about 1 month ago. I have noticed
since then that the unit shows the following behavior:
The unit turns on from standby for no reason at apparently random
times of the day.
While listening to the radio on the unit, the station can
spontaneously change frequency. The volume can change also. The
frequency can then alternate between two different frequencies.
Sometimes the unit will not respond to commands from the remote
control and will often react differently to the command.
Is anybody familiar with this behavior?
What has caused the unit to function like this?
Any ideas on how can it be fixed.
Thanks
SB
Scott Dorsey
Guest
Posts: n/a
      10-22-2010, 10:39 PM
When seemingly unrelated problems happen at the same time, look for
what they have in common. That means the control microprocessor,
the associated electronics, and the power supply to them. And that
latter part means checking for bad decoupling caps and bad solder joints
as well.
I absolutely hate working on this kind of consumer gear and it is usually
not worth the labour to repair. But I would first get the schematics
from Sam's Photofacts or the manufacturer and start looking around with a
scope on all the lines near the microprocessor.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Mark
Guest
Posts: n/a
      10-22-2010, 11:09 PM
On Oct 22, 5:31*pm, SB <paulsheeha...@yahoo.com> wrote:
> I have a Pioneer X-NM1. *I bought this new in December 2002. *It has
> been functioning fine up until about 1 month ago. *I have noticed
> times of the day.
> spontaneously change frequency. *The volume can change also. *The
> Thanks
> SB
sounds like a problem with the remote cont section,
is it an IR type?
try covering the senor with a piece of black tape, if that stops the
random behavior, then something is interfering with the remote..
Mark
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
JBL LE 5-2 midrange driver acting up Ty Ford Pro Audio 1 07-21-2011 04:02 PM
Adcom 535 acting up jamesgangnc High End Audio 14 07-28-2009 12:46 AM
Old Klipsch ProMedia v2-400's subwoofer acting weird. Time for anew speaker set? Ant Audio Equipment 4 12-08-2007 04:51 AM
power tube acting as a capacitor? apa Pro Audio 9 08-27-2006 03:40 PM
Pioneer DV-563A HDCD compatibility Tcheb High End Audio 6 11-07-2003 07:27 PM
