Audio Forums
Reply
Thread Tools Display Modes
Playing FLAC music from PC through S/PDIF to receiver - what's thebest solution?
Esben von Buchwald
Guest
Posts: n/a
      04-09-2006, 10:23 PM
Hi
I've ripped my CD collection to FLAC files (Free Lossless Audio Codec),
and I wonder how to get the best sound possible from the computer.
Currently i use this setup:
Computer with Windows 2003, running Winamp with FLAC plugin to play the
music. The sound card used is called something like nVIDIA MCP
SoundStorm 2 Audio, and has both analogue and S/PDIF output
(coax/optical). The receiver is a Sony STR-DE 475 (5 ch, DD/DTS support
etc.). Computer and receiver are currently connected with a cheap
standard coax S/PDIF cable.
I want the S/PDIF signal from the computer to be the best possible,
ideally, it should be the raw untouched data from the decoded FLAC file,
just like when playing an audio CD in an ordinary CD-player.
But I've heard that this is almost impossible on ordinary sound cards,
because they always resample any output to 48KHz, which is the only
sampling rate supported by the S/PDIF port. I know that the SoundBlaster
Live! does a really bad job about this resampling, and therefore, you
can install a Winamp plugin that does the job better with an improved
algorithm. But what about my nVIDIA MCP Soundstorm sound card?
MVH: Esben von Buchwald
http://www.sbn.as
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
rock version of Mr. Bojangles from Seph de Montreal Seph DM Cubase 0 03-16-2013 11:38 PM
Questions from a newbie Zelix Cakewalk 0 02-28-2013 01:56 PM
How to export projects from SX 1.06? Prospero Spooks Cubase 2 10-31-2012 08:40 PM
Output 2 stereo wav files from computer to a mixer? John Bennett Pro Audio 3 09-14-2012 07:43 PM
