Audio Forums
Reply
Thread Tools Display Modes
Question on 1960's Shure PA Column Speakers
Dish
Guest
Posts: n/a
      06-15-2004, 06:27 PM
Hi, I just bought 2 old Shure PA columns, you know, the heavy 5
footers. I was told they are from the 1960's. They look older than the
Shure columns i've seen on eBay lately. Mine do not have a silver line
running down the middle of them from top to bottom.
They are model SR103, and the plate has two wattages listed, 78 and
34. Was that for when there were more than two columns wired together?
Anyway, my question is... what exactly do I have here? I've spent a
day on Google and haven't found much, except when I searched on
"VocalMaster". Mine do not say VocalMaster on the front or on the
plate, though. And it seems like people rip VocalMaster PA systems
anyway.
Any info you can give me would help. And a manual or web address with
similiar info would be awesome. Is there any way to determine their
age?
My plan, unless they have great value, is to add a 1/4 plug, and use
them with a head for my Fender Strat. But I don't want to mess with
them if they are rare or something, not because of value but because I
have a thing about keeping rare, vintage things in their original
state.
Thanks,
- D Man
__
__
N
Guest
Posts: n/a
      06-16-2004, 06:12 PM
http://www.audio-forums.com/(E-Mail Removed) (Dish) wrote in message news:<(E-Mail Removed). com>...
Sorry, I remember them, but no details. Here's a search of Vocalmaster
from www.shure.com:
http://ss634.fusionbot.com/cgi-bin/s...almaster&rel=0
Here's some info from shure.com:
http://164.109.27.207/pdf/discontinued/sr102.pdf
http://164.109.27.207/datasheets/gui...continued.html
> anyway.
> age?
Just go to www.shure.com, like I did.
> state.
I have no idea if these things are rare/valuable/desirable. If I had
to guess, I'd guess they're not.
BTW, based on what I found at the above URLs and the data sheet, you
could just attach a female 1/4" input to a speaker cable, then attach
the wire ends of the cable to the inputs on the speaker cabinet. No
need to add a 1/4" input to the speaker cabinet. See page 4 of the
data sheet for more info.
> Thanks,
> - D Man
N
Guest
Posts: n/a
      06-16-2004, 06:14 PM
from www.shure.com:
> anyway.
> age?
> state.
> Thanks,
> - D Man
oldsoundguy
Guest
Posts: n/a
      06-16-2004, 07:17 PM
>from www.shure.com:
>From:
>> anyway.
>> age?
>> state.
>> Thanks,
>> - D Man
You have Shure Vocal Thrashers .. the ultimate piano lounge/cover bar
band (that wore spandex and polyester uniforms) PA .. not even
suitable for a rehearsal system for any serious band!! The frequency
response is a very ratty & distorted mid range only!
Mark Oppat
Guest
Posts: n/a
      06-20-2004, 04:25 AM
If these are identical guts to the old Vocalmaster columns, they should have
one 10" speaker and three 8" I think... is that right?
If so, they are also wired in series so each cabinet is 24 ohms total. You
were supposed to run up to 4 of them in paralllel, so you had 6 ohms when
all were used.
VERY ineffiecient speakers. Also there was a rear vent to cancell out the
very low end.
I took a pair once and made them much better by removing one of the 8"
speakers and adding a horn mid with xover. Then, I sealed the rear vent. I
wired the pot to the horn only for control of that. the open area around
the horn became a front port for the low end...
It actually improved it 100%!, plus the total impedance became about 4ohms
when done (I kept the 10", one of the 8", so those were 4ohms in parallel,
and the horn with a xover was pretty high impedance.
Mark
(infrequent lurker, former pro sound man)
"Dish" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed) om...
> anyway.
> age?
> state.
> Thanks,
> - D Man
> __
> __
Junior Member
      12-25-2009, 04:18 PM
Greetings,
With regards to your questions about your Shure columns, what you have are GEMS!
I ran across mine at a junk shop, got two for $100 each. I have regretted ever since not snagging two more that were available too.
Best performance is achieved via a 72-volt configuration (less line-feed resistance over long runs), but these babies are phenomenal for just about any situation.
I've used them for indoor and outdoor events for nearly 10 years now, and they perform just as cleanly as the day they came home to live with me.
You can download (as PDF) the spec. sheet for both at:
http://shure.com/stellent/groups/pub...o_sr102_ug.pdf
Enjoy your acquisition. Ya done good!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
1960's AM Radio question bitman1@aol.com Pro Audio 10 12-02-2008 12:00 AM
Singapore southern coast exotic funnel-type column yatuo-kui Pro Audio 0 06-11-2007 12:29 PM
Out Column... Dave Cubase 1 08-20-2004 03:28 AM
Question on 1960's Shure PA Column Speakers Dish Pro Audio 2 06-15-2004 10:19 PM
Critique My Reply from SOS "Readers Advice Column" JB Pro Audio 0 03-07-2004 10:34 PM
