I thought you meant you had one soundcard out, so you'd need cabling in that
case. If you have multiple outs you can use a virtual audio cable if the
software you're using (e.g. Windows Media Player) doesn't have this feature.
http://software.muzychenko.net/eng/vac.html free trial to make sure it
works for you before buying it. Or use a different player, such as VLC...
I don't use WinAmp very often, I don't recall if it has this feature or if
there is a plugin for it.
Sue Morton
"gray asphalt" <(E-Mail Removed)> wrote in message
news:E7fin.1974$(E-Mail Removed)...
> That's going to work. Thanks Sue. I didn't know there
> was such a thing as doublers. I wonder though, since
> Media Player can play to one set of USB speakers while
> VLC can play to another at the same time, USB or soundcard,
> if there isn't a way to do this through software. I'm going
> to Amazon to find doublers, now ... : -)
> "Sue Morton" <867-(E-Mail Removed)> wrote in message
> news:hmbu73$l43$(E-Mail Removed)...
>> Put doublers (not splitters) your output from your soundcard, and run the
>> lines to wherever you like? If you have wireless speakers that's even
>> easier, just wire to your transmitter.
>> If you want to pick and choose what speakers receive the output, use
>> switchboxes on the output from your card.
>> The sky's the limit... as long as your budget has no limits :-)
>> Sue Morton
>> news:Nzein.253$(E-Mail Removed)...
>>> I'm having a blast ripping a bunch of classical
>>> CDs with Exact Audio Copy. It converts them to
>>> MP3 using "Lame", an external codec. I know
>>> you probably know all about this. Anyway, I'm
>>> wondering if I can send music to different sets
>>> of speakers in different rooms ... they can be USB
>>> or from one or two audio cards but I'd like to use
>>> the same player.
>>> Sort of like inserting a "send" in Sonar, but with
>>> just a player.
>>> Are you having fun too?
