Audio Forums
Reply
Thread Tools Display Modes
Sennheiser Repair
BnE
Guest
Posts: n/a
      05-21-2010, 03:41 AM
Anyone know of someone other than Sennheiser itself who repair
Sennheiser shotguns mics?
jowillie
Guest
Posts: n/a
      05-21-2010, 11:02 AM
My experience of service for my MKH416 was very favorable with
Sennheiser.
Scott Dorsey
Guest
Posts: n/a
      05-21-2010, 11:25 AM
In article <(E-Mail Removed)>,
Depends what is wrong and which shotgun it is. But Sennheiser support is
actually very good and very reasonably priced. They'll even support the
MKH108 although some parts are no longer available. There are other folks
out there, but they'll be paying list price on parts.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Sofa Slug
Guest
Posts: n/a
      05-28-2010, 12:45 AM
http://www.locationsound.com/
Dave O'Heare
Guest
Posts: n/a
      06-13-2010, 04:50 AM
http://www.audio-forums.com/(E-Mail Removed) (Scott Dorsey) wrote in
news:ht5qj8$f12$(E-Mail Removed):
> In article
> <(E-Mail Removed)>,
> is actually very good and very reasonably priced.
Unless, of course, one lives in Canada. I tried to get a couple of MD421s
repaired, and was quoted $300+shipping each. Yikes.
Dave O'Heare
Scott Dorsey
Guest
Posts: n/a
      06-14-2010, 05:01 PM
>> In article
>> <(E-Mail Removed)>,
The 421 is a particular problem.
The 421 element is actually intended to be repairable... you can in theory
replace the diaphgram and coil very easily with a bench vice and a soldering
iron. The thing is, the diaphragm and coil assembly has not been sold as
a replacement part for ages.
This means that you have to replace the whole element when it goes bad, and
the whole element is a big thing that takes a lot of precision machining and
costs around $200. You can have Sennheiser put it in or you can do it
yourself, either way you have to spend a lot of money to replace the whole
damn thing.
And the WORST part is that the 421 has been replaced with the 421 Mk II...
so even though it's almost as cheap to just throw the mike away and buy
a new one, the new ones sound completely different and aren't anywhere near
as useful. So you pretty much have to bite the bullet and pony up. It is
really annoying.
--scott
BnE
Guest
Posts: n/a
      06-15-2010, 12:21 AM
> >> In article
> >> <(E-Mail Removed)>,
> >> Depends what is wrong and which shotgun it is. *But Sennheiser support
> >Unless, of course, one lives in Canada. *I tried to get a couple of MD421s
> iron. *The thing is, the diaphragm and coil assembly has not been sold as
> costs around $200. *You can have Sennheiser put it in or you can do it
> damn thing.
> And the WORST part is that the 421 has been replaced with the 421 Mk II....
> as useful. *So you pretty much have to bite the bullet and pony up. *It is
> really annoying.
> --scott
> "C'est un Nagra. *C'est suisse, et tres, tres precis."
Hope a MKH 416 T isn't as poorly designed.
Scott Dorsey
Guest
Posts: n/a
      06-15-2010, 01:20 PM
>> The 421 element is actually intended to be repairable... you can in theor=
>y
>> replace the diaphgram and coil very easily with a bench vice and a solder=
>ing
>> iron. =A0The thing is, the diaphragm and coil assembly has not been sold =
>as
>> This means that you have to replace the whole element when it goes bad, a=
>nd
>> the whole element is a big thing that takes a lot of precision machining =
>and
>> costs around $200. =A0You can have Sennheiser put it in or you can do it
>> yourself, either way you have to spend a lot of money to replace the whol=
>e
>> damn thing.
No, no, it's not a design problem at all. It's a support problem. The
421 was _designed_ for easy and cheap repairability, the problem is that
they won't sell you the parts to do the cheap repair any more.
That's the case for some things on the 416T also...
--scott
Ty Ford
Guest
Posts: n/a
      06-15-2010, 03:01 PM
On Mon, 14 Jun 2010 20:21:11 -0400, BnE wrote
(in article
<(E-Mail Removed)>):
>> damn thing.
>> really annoying.
>> --scott
Gear gets old or is abused and dies. Get over it.
FWIW, I was comparing my 421 to the e-609 and found them extremely similar in
sound.
Regards,
Ty Ford
--Audio Equipment Reviews Audio Production Services
Acting and Voiceover Demos http://www.tyford.com
Guitar player?:http://www.youtube.com/watch?v=yWaPRHMGhGA
Scott Dorsey
Guest
Posts: n/a
      06-15-2010, 04:51 PM
Right, but you should be able to fix them when they do. And you should be
able to get the parts to fix them.
>sound.
Agreed. The pattern is a little different, but the lack of a presence peak
is very notable on both. There aren't a lot of dynamics that flat.
--scott
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
OT Sennheiser G3 repair Gareth Magennis Pro Audio 3 03-09-2013 03:35 PM
sennheiser way to go with nature recordings: Sennheiser MKH-40 pair or Sennheiser MKH-30 + MKH-40 combo? andrejs eigus Pro Audio 4 02-25-2007 09:17 PM
Sennheiser HD 580 cable repair Andre Majorel Pro Audio 6 03-28-2006 10:09 AM
how much to repair a sennheiser 441? seanbroderick20003@yahoo.com Pro Audio 7 07-22-2005 02:57 PM
Sennheiser HD-570 repair scottm High End Audio 2 02-12-2005 12:49 AM
