Audio Forums
Reply
Thread Tools Display Modes
Re: Speaker Wire
WindsorFox[SS]
Guest
Posts: n/a
      07-01-2003, 04:41 AM
wsroot wrote:
> Thanks Kal
> One final question if you don't mind this type of wire ( one side copper the
> other side silver ) will not effect the quality what so ever I am using 16
> gage as well ???
> I was always told not to use silver componets connections on the stereo so
> is the one side really silver of just colored copper ??
> Thanks so much
Uhhh, you need to understand that having one side of your zipcord
tinned with a clear jacket is so you can tell your + and - appart.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Re: Speaker Wire 0junk4me@bellsouth.net Pro Audio 0 12-01-2008 11:00 PM
Re: Speaker Wire Scott Dorsey Pro Audio 17 06-24-2008 12:12 PM
Re: Speaker Wire Scott Dorsey Pro Audio 0 06-23-2008 01:57 PM
Re: Speaker Wire Scott Dorsey Pro Audio 0 06-23-2008 01:46 PM
Solid core copper 18 guage thermostat wire - problems as a speaker wire? Adam Law High End Audio 2 07-18-2003 06:08 PM
