Audio Forums
Reply
Thread Tools Display Modes
T1AL fuse for Soundcraft mixer
Paul P
Guest
Posts: n/a
      03-04-2009, 02:25 AM
I just bought a nice Soundcraft EPM6 mixer and see that it
has a T1AL-250v fuse. From searching on the net this seems
to be a very common fuse on electronic stuff coming out of
the UK.
I'm in North America and I can't find anyone on the net
that lists these fuses (tried Mouser, Allied, Radio Shack,
Digi-key etc). Nor can I find any conversion chart to
something equivalent. I can't even find a specification
for the fuse, even in the UK.
The mixer is new so I don't need a fuse right away but
would like to have one on hand. Can someone provide me
me an American equivalent to the T1AL fuse ? Thanks.
Paul P
Scott Dorsey
Guest
Posts: n/a
      03-04-2009, 03:16 AM
>the UK.
If it's a 1A fuse 5mm around and 20mm long, look for an F1 or a GMA-1.
Your local auto parts store should have them.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Scott Dorsey
Guest
Posts: n/a
      03-04-2009, 02:39 PM
Fred <(E-Mail Removed)> wrote:
>F1 = 1 Amp, Fast acting
>T1 = 1 Amp, Time delay (Slow Blow)
>The OP needs a T1, not an F1. There are several varieties available with
>somewhat different
>characteristics, but any commonly available T1 rated fuse will work in his
>application.
Yeah, the auto parts stores won't have slow-blow fuses in stock, but
Digi-Key should. And Cain Electronics in Norfolk, VA definitely does.
--scott
Paul P
Guest
Posts: n/a
      03-04-2009, 05:03 PM
Thanks guys for your help. I just got a very quick answer back from
Littelfuse whom I should have asked before bothering you. The fuse
is indeed a 1 amp time delay 5x20 mm inline fuse.
So for the sake of future searchees the Littelfuse equivalent to the
T1AL-250v is 218001, available from Mouser, etc.
Paul P
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Fuse Dilemma Casper High End Audio 9 07-30-2008 11:29 PM
Input (MAINS) AC Fuse Chief_Billy@hotmail.com High End Audio 3 05-07-2008 10:38 PM
Changing Fuse in Mackie Hard Disk Recorder jayjudell@gmail.com Pro Audio 14 08-10-2005 09:43 PM
soundcraft series 2 vs soundcraft 1600 wich to use? labpartner Pro Audio 7 10-31-2004 11:32 PM
Yamaha NS-10's inline fuse modification Martin Martini Pro Audio 1 12-02-2003 02:37 AM
