a while back there was a discussion thread here about a small silvery Sony
HD FM receiver that was supposedly really good - so I bought one - I don't
like the user interface, but I thought I'd post about a design flaw - on my
unit at least, the audio quit intermittently, and a few days ago would quit
entirely in both channels - took it apart (that's a bit of a chore, to get
the circuit board out without destroying it) and found that the traces that
connect to the RCA jacks, center conductor (e.g. high side) had both broken
right where the through hole for the conductor is - very thin traces - they
should have been larger - I don't know if the cause was thermal or
mechanical stress, but whatever it was, there was no continuity from the
surface mount device in series with the output and the output itself - so
the solution was then straightforward - add a jumper wire from the device to
the output jack that would bypass the defective trace on each channel -
I used to think Sony meant quality (or at least good consumer quality) - I
doubt it now - this radio does get better reception than what it replaced,
but it's a real PITA to use and now with a design flaw like this....grrr
Bill -
www.wbnoble.com
