biwire or jumpers?
Discussion in 'Hi-Fi and General Audio' started by huuge, Apr 1, 2006.
  1. huuge
    huuge
    Mar 16, 2005
    48
    Have just changed layout from monoblocks to integrated
    I used to biwire my monoblocks(electrofluidics 20/20 1m lengths - offers?)
    But now need 5m lengths!
    It's suggested that single wire and jumpers(same cable essential?) is as good or near as dammit
    Any views?
    huuge, Apr 1, 2006
  2. huuge
    RobHolt Moderator
    Oct 24, 2004
    9
    Don't use jumpers if at all possible.
    If you can, remove the speaker connection panel and hard wire the terminals together to allow the use of single wiring.
    Rob.
    RobHolt, Apr 1, 2006
  3. huuge
    huuge
    Mar 16, 2005
    48
    but I'm a diy tyro
    Is it really better than the supplied wire bits or jumpers?
    huuge, Apr 1, 2006
  4. huuge
    Sid and Coke
    686
    East Coast Scotland
    Well as you are asking for personal opinions then mine is : Full length Bi-Wire. I recently tried going back to a single wire with jumpers config for a few weeks and just thought that there was a degree of 'something missing' , veiling, lack of detail call it what you will.
    I am a semi cable sceptic too, so it is quite a thing for me to even admit that i thought it made a difference - but I did :D.
    Sid and Coke, Apr 1, 2006
  5. huuge
    Chris
    120
    Canaries
    FWIW I have just gone back to my thick old faithful PCOCC Furukawas because my new Sugden A21SE just didn't get on with my previous "avionics" spec silver (coloured ?) i/c cum speaker wire which had worked so well with my Sugden A21a and I dispensed with my jumpers by removing a half inch section of "dielectric" about 3 inches from the end of my cables, tinning it and inserting the cable through the bass terminales to make said section coincide with the screw down and thence on to the hi terminals. Of course this is possible because the Totem terminals are BIG and hence the hole is also quite large. Sounds good, I reckon. suck it and see.
    Chris, Apr 1, 2006
  6. huuge
    lordsummit moderate mod
    3,650
    In the Northern Wastelands
    Jumpers, sound much better than bi-wiring on mine. Bi wiring screws the timing up for me.
    lordsummit, Apr 1, 2006
  7. huuge
    mr cat Member of the month
    Jul 31, 2003
    3,375
    5
    i would say jumpers, but if you've already got the excess cable then why not try both and see what works best..?
    I went from bi-wire to jumper (no reall difference imo) before i bi-amped
    mr cat, Apr 1, 2006
  8. huuge
    GAZZ
    Jun 21, 2003
    597
    northwest
    If you are buying cable use jumpers, 1 length of £10 or 2 lengths of £5
    GAZZ, Apr 1, 2006
