Is there a device which can convert 2 audio inputs into 1 input?
Discussion in 'Hi-Fi and General Audio' started by malzed, May 11, 2016.
  1. malzed
    malzed
    May 11, 2016
    I'm new here ...
    I've got a Speaker(amp) which have one audio entry (jack) ...
    I'd like to put 2 output in it (tv and hifi) ...
    Should I make a simple Y cable ? Or can I bought a device which accept 2 entry and convert signal into one ?
    I don't want a switch ... I would like to have a device which could take the current playing line, or both (if both are playing) ...
    Is this kind of device exists ? where could I buy it ?
    Don't want an audio/pro system ... Just want the simplest/cheapest thing ...
    Thanks in advance
  2. malzed
    kuifje19
    Feb 4, 2016
    22
    You could make a simple y cable to connect both outputs to 1 input, but they will influence each other.
    You can try if it suits you, but it is not the best solution.
    I would at least add some resitors in series to each channel, to reduce the fact the tv and the hifi will see the other. You could use a stereo pot-meter to fade between TV and HIFI...
    But the other way... Why dont you connect the TV to the HIFI and the HIFI only to the Spaeker system.
    kuifje19, Jun 8, 2016
  3. malzed
    Carole Lee-Stone
    Jun 29, 2016
    Definitely !!
    Carole Lee-Stone, Jun 30, 2016
