I'm curious about how people in this forum angle their loudspeakers. In music circles, the majority of people these days are using so-called near-field monitors, positioned close to the sound engineer. These were initially chosen for economic reasons and to better match home systems, but it's become more of a standard. It's generally recommended that these be angled with the axis of the loudspeaker pointing directly at the head of the listener - and in a stereo set up, the listener and the two speakers should form an equilateral triangle. As I understand it, on-axis placement is used because most loudspeakers (near-field monitors at least) give a flatter frequency response when positioned this way rather than off-axis - so the engineer is less likely to swayed in his/her mixing decisions by any change in tone colour introduced by an off-axis placement. I have a home studio with a pair of "mid-field" Tannoy System 12 DMT II monitors. In the manual for these, it's recommended that the speakers be placed between 2 and 4m apart and that the "distance between the monitoring position and each speaker should be slightly greater than the distance between the speakers". In the case of these speakers it's also recommended that they are angled between 10 to 15 degrees off-axis to give "the optimum spread of HF information" - which I assume means: to get the high frequency part of the spectrum is at its flattest. I wonder though that there's not also the question of the scale of the sweet spot at play. Near-field monitors are better suited to a single listener, whereas mid-field and far-field monitors give a bit more space to squeeze in a few smelly musicians around the engineer. Perhaps too, an off-axis speaker angle helps to reduce cross-talk (between ears), or at least stops the possibility of an inversion of the stereo image by not allowing the channels to cross paths within the confines of the room. OK - so in the audiophile/hi-fi world, what do people do? I've often heard people recommending parallel speaker placement or with a "shoe-in" angle adjustment. What's the reasoning behind this? It'd be interesting to hear what people here get up to. Cheers, Iain
