What glue to use on speakers?
Discussion in 'Hi-Fi and General Audio' started by Heavymental, Mar 27, 2006.
  1. Heavymental
    Heavymental
    Dec 10, 2003
    877
    My Epos ES11's have a rubber seal around the woofer that has come unstuck. On some tunes I now get a slappy noise where the loose rubber is vibrating. I need to glue it back onto the main cone but was wondering what to use. Its going to be difficult to put much pressure on as I don't want to take the speaker apart so something that will stick well and quickly would be nice. Any suggestions or will plain superglue be ok?
  2. Heavymental
    hifikrazy
    Jan 22, 2004
    244
    You really need a replacement drive unit to be honest (preferably 2 for matching - although im not sure if epos have es11 drivers anymore). Driver repairs are not very easy to do and sometimes do more damage than good when attempting a diy job. There are individuals that might be able to refurbish drivers who usually specialise in older stuff like tannoy and goodmans.
    If you were going to attempt it yourself you would probably want stuff that doesnt set brittle, something with a little flex, so possibly not superglue. Perhaps someone else can suggest something more suitable.
    hifikrazy, Mar 27, 2006
  3. Heavymental
    penance Arrogant Cock
    Jun 30, 2003
    6,004
    Bristol - armpit of the west.
    Evo-stick sets with a fair amount of flexibility.
    But as hifikrazy says, it would be better to replace the driver, also there is a risk of the glue having an adverse effect on the cone materials.
    penance, Mar 27, 2006
  4. Heavymental
    Paul Dimaline
    Jan 14, 2004
    135
    I dont have a link but have a look on the Loctite web page, there is a large (pdf I think) file that gives detailed info on what adhesives to use for all aspects of building a speaker drive unit.
    A bit heavy going but quite interesting in parts.
    Paul Dimaline, Mar 27, 2006
  5. Heavymental
    la toilette Downright stupid
    Jan 21, 2005
    1,213
    Somerset
    I've repaired a couple of pairs Tannoy speakers whose foam surrounds that have gone rotten, the glue used in this process is water based, and I remember reading that you should specifically avoid spirit based glues as these may have an adverse effect on the cone material. I bought my repair bits from speakerbits.com (predominantly because they're the only source of genuine Tannoy foam surround replacement parts for DIY repair that I know of) and you can order speaker repair glue from them, but unfortunately they're based in Australia so postage cost is an issue. :rolleyes:
    Their glue retains flexibility and I've used it to stick down a flapping rubber surround on some other speakers as well with very satisfactory results.:D
    If it's a case of repair or replace, then you may as well have a go at repairing as you have nothing to lose!
    la toilette, Mar 27, 2006
  6. Heavymental
    Tenson Moderator
    Nov 12, 2003
    5,947
    Ask Wilmslow?
    Tenson, Mar 28, 2006
  7. Heavymental
    JohnT
    Dec 28, 2004
    24
    Weymouth, Dorset, UK
    I've seen a couple of US sites that sell speaker foam repair kits, I believe they use ordinary white PVA glue as also used for woodworking. Here we are:
    http://www.newfoam.com/kits.asp
    http://www.speakerworks.net/kits.html
    Replacing one or two drivers seems a bit drastic for what sounds like a fairly simple re-gluing job if the foam isn't split or damaged and you're prepared to have a go. If not you could try contacting Richard Allan who do a lot of speaker repair work, they can be found here:
    http://www.loudspeakersonline.com/
    HTH
    John
    JohnT, Mar 28, 2006
  8. Heavymental
    Jan 21, 2005
    1,213
    Somerset
    I think the glue I used was PVA based, but I'm pretty sure it wasn't the same stuff used for woodwork, as that dries much much harder and I wouldn't think it's a suitable choice.
    Good call on the Richard Allan site though, they might be able to offer either advice or repair service - I was just looking at that site yesterday as I picked up a pair of old Richard Allan RA8's for £1 t'other day to go in my workshop!!:eek:
    la toilette, Mar 28, 2006
  9. Heavymental
    Heavymental
    Dec 10, 2003
    877
    Cheers chaps. Will try to glue as its only really a small bit of rubber that is loose and it will glue onto the plastic surface of the driver rather than any fragile material so wouldn't have thought it would do any damage.
    Will get in touch with Richard Allen to see what glue he advises.
    Cheers,
    HM
    Heavymental, Mar 28, 2006
