Sean Conolly <(E-Mail Removed)> wrote:
> "Peter Larsen" <(E-Mail Removed)> wrote in message
> news:4f24358b$0$56773$(E-Mail Removed) k...
> > Hi Guys,
> > here is how to get a spot microphone just right if you again forgot
> > measure or record a clap near it:
> > 1) know the order of magnitude of the required delay so that you start out
> > close to right
> > 2) pan suitable main pair microphone fully left or right
> > 3) pan spot mic fully right
> > 4) get volume reasonably balanced
> > <this does it!>
> > 5) adjust delay for proper center image of spot microphone sound source
> > </this does it!>
> > 6) add a few milliseconds if spot microphone sound source protrudes when
> > properly mixed.
> > Note: adjustment sensitivity is single milliseconds. May for some be
> > easier when listening via headphones and for some be easier when listening
> > via loudspeakers, not fully verified what works best, try both!
> This is one case where I prefer to use my eyes: in the DAW drag the spot mic
> back (time delay) until it lines up with the main mics. You just have to
> find a place in the music where the instrument being spotted is prominant
> enough to see in the main waveform.
> Sean
Works when using a DAW, but not for situations where one will be
capturing a stereo mix. It can be helpful in the latter setting to get
it as right as possible from the gitgo.
When in the DAW, I will use my eyes to get close, and then close my eyes
to listen until I lke it. Sometimes I will get down to nudging by the
sample.
shut up and play your guitar *
http://hankalrich.com/
http://www.youtube.com/walkinaymusic
http://www.sonicbids.com/HankandShaidri
