I wouldn't say meaningless but impractical, yes. No one wants to see a
4 inch panel protruding two feet to the front in the center of the
room.
I think it helps for better separation and localisation of sound . I
know Track 8 the sleigh comes from my BACK and goes to left and right
with consistent volume. Previously it was coming in front of me as
described by
http://www.positive-feedback.com/Issue18/waters.htm .
It was just an experiment and I thought people with acoustic
engineering, sound recording engineers or similar background may want
to give their input. I am hearing a difference and for now I am
confining to Track 8 -Too much Rope.
Regards,
ST
On Aug 3, 12:14*am, Norman Schwartz <n...@optonline.net> wrote:
> On Aug 2, 12:33*am, ST <st.chel...@gmail.com> wrote:
> > On Aug 2, 4:55*am, Dick Pierce <dpie...@cartchunk.org> wrote:
> > > ST wrote:
> > > > Hi to all,
> > > > Recently, a friend was talking about High End system which supposedly
> > > > make the loudspeakers disappear. While driving back I realized that it
> > > > is much more easier to achieve the act of making speakers disappearing
> > > > in a car then our room. The front sound from my car speakers appear to
> > > > come from the dashboard/bonnet even though the speakers are located
> > > > somewhere below my knee level on my right and left door and each
> > > > speakers can't see each other because they were blocked by the car
> > > > center components. But they project the sound beautiful to my front
> > > > which makes them appear to come from the windscreen/dashboard/bonnet
> > > > in front of me.
> > > I'd bet good money that if you looked on the top of the dash,
> > > you'd find two small tweeters firing up and reflecting off the
> > > windshield. That's why you're localizing the sound to there
> > > and not to the speakers in the doors. The high frequencies
> > > of those tweeters is triggering your aural localization, and
> > > overwhelming the localization from the in-door speakers.
> > > Your proposed experiment with the absorber between the speakers
> > > is likely to fail, since the effect you seek (what you hear
> > > in your car) is not anything like what you think it is.
> > > + * * * * Dick Pierce * * * * * *|
> > > + Professional Audio Development |
> > Hi,
> > Yes, the two tweeters are on the dashboard but even with them turned
> > off the sound is still coming from the front though bit lower and
> > obviously lacking clarity. You are still unable to pin point where the
> > speakers located.
> > Regarding my experiment -
> > I used Roger Waters -Amused to Death, Track 8 - Too much rope.
> Since the proximity and relections with respect to your listening
> room's boundaries, as well as its *volume are nothing like you car's,
> isn't your experiment somewhat meaningless regardless of its outcome?
> Norman
