On Oct 10, 10:03*am, Jos <skelt...@ziggo.invalid> wrote:
> >> >>Anyone know how to change the velocity of the 'piano keys' in the key
> >> >>editor?
> >> >>It is preset at 127, not the best for previewing notes on sounds with
> >> >>velocity switches like those on trilogy bass module.
> >> > In the key editor, at the top of the screen, to the left of the
> >> > 'snap' button, there is a small indicator that says 'ins. vel.' There
> >> > you can adjust the standard velocity of hand-drawn notes. Is that
> >> > what you mean?
> >> I don't think that is what Paul means. The vertical keyboard on the
> >> left can be used to preview notes (as opposed to inserting them). I.e.
> >> clicking a key with the mouse triggers the note. This preview has a
> >> fixed velocity of 127, which is annoying. I would like to find a way of
> >> lowering that value myself.
> > You are right, I am referring to the previewing of notes using the keys
> > on the key editor.
> I found a way around this, more or less. On the MIDI track, in the
> Inspector, open the MIDI Transform window, and enter the following:
> Conditions:
> Type equal note
> Velocity equal 127
> Actions:
> Velocity set to fixed value 64 (or whatever)
> This acts as a real-time filter. Be sure not to use actual notes with
> velocity 127 in your work, or remember to turn off the filter.
> Sadly, it only works for that specific track.
> Jos.
That'll have to do, nice one!!
Thanks
