"DonMack":
> When I record an audio file and try to put into musical time the audio
> always becomes out of sync.
> The steps I follow are:
> 1. Record audio block
> 2. Edit block and add warp tabs to the first beat and sometimes more to
> fix up timing issues
> 3. Enable musical time on the track
> 4. Enable musical time in the Pool. (when clicking on it is when it gets
> screwed up)
> It seems to have something to do with the audio files that have an gap
> before the first beat.
This is kind of "normal", no matter if audio is recorded with linear or
musical time mode.
(If you havenīt already: activate "Show Event Info Line" in the toolbar!)
Record a "block" of audio and select it, then look at the "Info Line" and
youīll notice a value for "Offset". This is, what causes the gap IME.
A work-around is to export/bounce that clip to a new file, that starts at
the "correct" time. This new file does not have that gap in the beginning.
Itīs also important for exporting individual track files for external
mixdown or archiving, to make sure, all audio files are really "in time".
Anyway, you might try setting an audio track to musical time, BEFORE you
record and see, if it makes a difference. Probably not, but it doesnīt take
much time to try.
Hope, that helps a bit,
Phil
