On energy xt (midi sequencer) it has some basic sound effects built in that
you can add to tracks, like if you added extra reverb to a SFZ track using a
soundfont. Is there any way I can add more effects to that sequencer?
The default reverb just doesn't cut it for me - I would like something like
the reverb options in the old Cool Edit, like Warm Room, etc.
I found uvisoundsource.com which has a great quality free module (I got a
useable bass, piano and drum kits out of the demo soundpack). Could you
recommend any others? Am looking for good piano and guitar sounds. Cheers
