Audio Forums
Reply
Thread Tools Display Modes
Why Does Time Stretching in Cubase Sound Bad???
Guest
Posts: n/a
      10-03-2010, 08:03 PM
I extrapolated a 16 bit MP3 to 24 bit, when I injected it
into Cubase. But then the audio file was a bit longer than
when I don't extrapolate. And, the audio sounds really bad in
places.
Then, I tried to time stretch the other tracks, to fit an
un-extrapolated MP3, and then IT sounds like ****!
Apparently, this time stretch function doesn't work
well in Cubase LE 4.
Scott Dorsey
Guest
Posts: n/a
      10-03-2010, 08:16 PM
>places.
Well, time-stretching is inherently never going to sound natural
since you're basically resampling everything and then shifting
all the tones by a factor.
But, time-stretching an MP3-encoded file is going to do that and
on top of that it's going to exaggerate all the MP3 compression
effects substantially.
Lossy compression is not acceptable for any kind of production work,
but if you're going to do stuff like resampling it's even worse than
usual.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Guest
Posts: n/a
      10-04-2010, 10:27 AM
On Oct 3, 1:16*pm, klu...@panix.com (Scott Dorsey) wrote:
> Paul *<quiller...@gmail.com> wrote:
> > * * I extrapolated a 16 bit MP3 to 24 bit, when I injected it
> >into Cubase. *But then the audio file was a bit longer than
> >when I don't extrapolate. *And, the audio sounds really bad in
> >places.
> > * * Then, I tried to time stretch the other tracks, to fit an
> > * * Apparently, this time stretch function doesn't work
> usual.
> --scott
Yeah, tons of aliasing and digital artifacts.
The MP3 was used just to demo ideas, but it's good
to know you cannot resample without severe consequence.
philicorda
Guest
Posts: n/a
      10-04-2010, 06:18 PM
On Sun, 03 Oct 2010 13:03:13 -0700, Paul wrote:
> I extrapolated a 16 bit MP3 to 24 bit, when I injected it into Cubase.
> But then the audio file was a bit longer than when I don't extrapolate.
> And, the audio sounds really bad in places.
Time stretching is always a bit weird, but there are a few things you can
do in Cubase to improve it. I use Cubase 4, and as far as I can tell this
function is identical in LE4.
There are two ways Cubase does time stretching. In real time, or as an
offline process. You can choose in the preferences which one it will use
by default, and the type of algorithm it will use.
When using the real time time stretching, (called 'warp') you need to
select the appropriate algorithm for the kind of audio for each track.
There are options for 'drums', 'plucked', 'pads' etc. This will make a
huge difference to how good it sounds. There is also an advanced mode
that lets you play with things like variance and grain size to get it
just right.
The other way is as an offline process. You get this by right clicking on
a section of audio and selecting timestretch from the 'process menu'.
This gives you more options to play with for different kinds of audio and
generally sounds better than the real time warp, except in the case of
drums or percussion.
There is a lot of depth and options to play with here, so read the
manual! The defaults are almost always wrong, as they don't know what
kind of audio you are stretching!
They have screwed it up unfortunately though, as the best time stretch
for many purposes was the old 'time bandit' one. This was in Cubase3 but
sadly vanished from version 4 onwards. Now there is just the realtime
warp which is a little buggy and somewhat painful to configure, and the
mpex offline stretch which is very slow, way too clever and sometimes
turns transient material into bubbling noises.
I generally just use the offline stretch, but you can use the realtime
one if you freeze or bounce the track after getting it right.
Mark
Guest
Posts: n/a
      10-10-2010, 01:09 AM
> > * * * Then, I tried to time stretch the other tracks, to fit an
> > * * * Apparently, this time stretch function doesn't work
see
http://www.dspdimension.com/admin/time-pitch-overview/
Mark
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Why Does Time Stretching in Cubase LE 4 Sound Bad??? The MAN Cubase 0 10-09-2010 04:26 PM
Realtime Time Stretching ºoºfizzyºoº Cubase 1 03-26-2005 07:04 PM
FS: Roland Variphrase Sampler VP9000 - Insane Time Stretching driven2 Pro Audio 0 08-11-2004 06:16 PM
continuous time stretching Daniel Schaedler Cubase 0 02-28-2004 08:45 PM
Time stretching? Jenna Cubase 0 02-25-2004 01:07 AM
