Haselsh1
Shaun H
My sound system at the moment comprises:
A Linn Basik turntable with an Alphason Xenon MCS tonearm and an Ortofon OM30 cartridge. An Original 2008F HDCD player imported by me from China into a Gemini PA7000 DJ preamp. This goes into a Samson Servo 600 power amp which in turn powers a pair of small Q Acoustics 1020i speakers.
The sound for me personally is just about what I want but I've got a bit of a DIY itch. I know that the Gemini preamp is a very cheap unit with a good phono stage as this stage is better than the Graham Slee Gram Amp 1 I was using before this came along. My point: I am thinking of upgrading all of the resistors in this unit for Tantalum types and all of the capacitors for Elna's. Would changing resistors and capacitors make a vast difference to the sound that comes through this unit...? If it changes the sound for the better then ultimately, it has to be worth it. Given the overall budget of my system I'm not about to go and throw away 400 quid on a ready built commercial pre and this is the main thinking behind what I'm planning.
What do you think...???
