which is your recommend to direct to krell 2250 power amp with dynaudio speakers?
in my expirence the dp67v will be a better bet, on a musical term, but the 390s will sway you on facilities and build cheers john
My suggestion is to buy the most expensive and famous CD player you can afford (or preferably one you can't really afford), as this will clearly be the best possible CD player you can buy. It's quite simple, really; more $$$$ = better.
the mark levinson volume control is much better than the accuphase, so i suppose thats the one you should go for cheers john
Amir I have a 39/380s/336. Although the 39 pre-amp function may appear to offer a cost saving, it's not anywhere near as good as a purpose built unit. I have used my 39 connected directly to my 336 and it's okay, but no-where near as good as using the 380S in the middle. People have told me the 390S is much better than a 39 it's no surprise that Levinson have recently announced two new pre-amps. If you decide to go down the Levinson path then I would budget for a 320S as well. The rumours are it's good value (for Levinson kit). You could go the whole hog and get a 432 as well.. Graham
