alesis BRC and alesis HD24
Discussion in 'Pro Audio' started by _The Dude_, Dec 6, 2004.
  1. _The Dude_
    _The Dude_ Guest
    hi group,
    anybody here with experience on this setup? i have a alesis BRC and a alesis
    HD24. i can figure out most stuff but one thing is bothering me, the record
    button doesn't work. i know there are some limitations on using the BRC with
    the HD24, the BRC was made to control a lot of adat's not the HD24. in the
    HD24 manual is clearly stated what to expect working and what not.
    sadly of the record-button not working nothing is listed.
    when i unplug the adat-sync cable the record button does work so it's not
    that it's broken, but when plugged into the HD24 it doesn't work
    i hope someone can help me here, kind of useless having a great remote but
    not be able to use the record button...
    thanks in advance
    G.
    1. Advertisements
  2. _The Dude_
    _The Dude_ Guest
    thanks wayne for this info
    i found out that indeed it won't start recording from 00:00:00:00, if i set
    it at 00:00:01:00 it does work...
    and i read the "read me" file of the latest firmware and apparently a lot of
    issues should be solved installing it...
    thanks again
    G
    1. Advertisements
  3. Join the HD24 group on Yahoo to reach people with extensive experience
    with this combination.
    http://groups.yahoo.com/group/hd24/
    Jim Gilliland, Dec 7, 2004
    1. Advertisements
