There Was A Big Improvement
HI All,
And thanks for trying to answer my Question, although I'm getting the feeling that both products will do the same. "michaelab" also asked if they make a difference. Well If you asked me back when the Trichord clock 1, was out. The answer was a hugh Yes, I remember and still have one fitted to my Old Phillips CD 950 Player, at the time I was using a Audio Alchemy DAC in the BOX, when the player came back I was amazed by the timing and Dynamics.
But I believe things have changed, as a lot of Manufactures did sit up and took notice. Back in the Days when HI-FI Choice would give you loads of techincal spec with a review,SONY & Marantz improved there clocks.
So I would imagine, the improvement from re-clocking isn't as hugh as it was back in the 90's, of course it all depends on your player.
My Pioneer DV 575 A isn't up to much, and yet my Old Toshiba 210E DVD Player has a really low jitter output.And the Sound Quality although a little Harsh, is streets ahead.
I am going to get a quote off Trichord, I know there is a bloke on ebay fitting the superclock 3 for about £200, so as long as the price isn't silly from Trichord we will go with them. Also I seem to recall reading a review about the superclock 1,in which the reviewer removed it, as he felt it made his player less Dynamic, (Back To Theory that his player may have had a good clock to start with!)
Again Thanks All, And I will Put up a Review once fitted.
