Behringer DDX3216 mixer
Discussion in 'Audio Equipment' started by Søren, Sep 3, 2011.
  1. Søren
    Søren Guest
    After repairing this mixer, I tried to flash it with a new firmware.
    After waiting for a long time, I restarted the mixer and now it won't
    start, program is missing:-(
    Searching for help on Behringer HP, I found this:
    DDX3216 Message: Program Not Loaded
    Solution
    When you get the fault description of an DDX3216 Program is not loaded,
    this is caused by an interruption during a firmware update attempt . In
    this case the flash eprom is erased and the mixer does not start up.
    There is an emergency tool (DDXupdate V1.11) available(Ask your
    BEHRINGER support dept.)to start up a DDX3216 when the firmware upgrade
    has failed.
    Søren, Sep 3, 2011
    1. Advertisements
  2. research it on google you should find it. Also you should try Behringer DDX3216 File exchange via midi that may work easier for you
    doveandtheserpent, Oct 5, 2012
    1. Advertisements
  3.
    1. Advertisements
