budget for protools HD system?
Discussion in 'Pro Audio' started by jakeirving123, May 25, 2006.
  1. hey all,
    whats the cheapest way to record 24 channels (analog input) with a
    brand new protools system, assuming i'm starting with zero equipment?
    i know i can just get some used 888s with 1 16ch card and 1 8 ch
    expansion card, but what about new systems, like one that would be
    compatible with a G5?
    the budget has to be within $10k (preferably around $7.5k) including
    monitor speakers, snakes, Mac, and mixing console.
    i am kinda considering using some other software like DP or cubase
    along with M-Audio Delta 1010LTs or presonus firepods, but my
    client/boss really wants a digidesign system for some reason.
    as far as i can see, the cheapest option is to get the protools HD1
    system for $8k plus (3) 96kHz protools HD interfaces. this is already
    way over budget. are there any other options? maybe m-audio?
    please help,
    thanks,
    jake
    1. Advertisements
  2. jakeirving123
    nappy Guest
    If you don't mind my asking.. how often will you really be recording 24?
    nappy, May 25, 2006
    1. Advertisements
  3. jakeirving123
    Zigakly Guest
    Assuming you're mixing through the console using mostly hardware processors,
    only one way I can think of:
    Get a basic 24-channel interface (Moto 24i/o or two Echo Audiofire 12's),
    record in another editor, import into Protools for editing as required,
    where you can do overdubs up to 18 tracks at a time with either a Digi002 or
    M-Audio FW1814, or 10 overdub tracks at 96kHz. When it comes to mixdown,
    Protools LE or M-Powered allows you to "consolidate" tracks, which makes
    them ready to export back to the editor which supports the 24-channel
    interface, which you then mix from.
    If you're welcome to the idea of mixing in-the-box, it's much simpler.
    Sounds like this isn't what your client/boss has in mind, but it's your only
    hope under $10k.
    Zigakly, May 25, 2006
    1. Advertisements
