I was unhappy about my high street systems lack of involvement musically so about ten years ago I got my first hifi = naim gear + tukans. Got inexpensive CD player as I felt they should all be the same. It didn't solve the problem but I kept telling myself it was lack of concentration on my part. Finally I had to do something about it - ended up unwillingly auditioning DAC64 and realised it solved the problem for me. I now believe that the various problems with CD playback (jitter and sampling rate) were the problem all along. I've never auditioned another DAC and I don't intend to - I've got my music back which is all I ever wanted. However I then found the Naim gear was too forward and too bright. Didn't want to change it but finally felt I had to. Web research and success of DAC64 led me to Chord and finally I auditioned and bought a SPM1200 secondhand - fantastic. I should probably have left it there (no doubt very famous last words) but I felt that the NAC72 was probably letting it down and maybe I should replace that while I was about it. Ended up getting a TVC as I liked the idea of them - as little interference with the signal as possible. Received it (a Django) about a month ago - also fantastic. Except.... I listen to classical and with some music I get a buzzing in the tweeter with piano at certain pitches (the C above middle C and the E and G above that) and also some strings (viols, for some reason - not a major problem as I don't like viols too much - they were on the radio). However this really annoys me as I feel it should now be pretty much blemish free (not perfect, but without any obvious defects). The speakers are still the Tukans, which I understand were designed to go with the Naim amps, but I still fell this shouldn't be happening - it doesn't when I replace the 1200 with the NAP140. I rang a Chord dealer who rang Chord for me who said this was a known problem and that I had to reduce the gain. The Django has a gain switch which gives you the option to increase the gain, but not to reduce it. Neither position solved the problem - and I don't know what 'gain' is in the first place. Is this problem known to you guys? I'd just like to know what the solution is likely to be. If it means selling the Django then so be it, but could it be that harder to drive speakers are the answer? Also while we're on the topic - I got hold of XLR cabling for my new toy - DAC to Django to 1200. So I was disappointed to find that it rendered all but three of the volume settings on the Django unusable. I realise that XLR removes noise by sending the signal twice, once inverted, and then subtracts the two eliminating noise and doubling the signal strength, but I didn't realise it would have such a drastic effect on the volume - I think I'd assumed that the signal was then halved back to the original level. Does double the strength equal twice the volume or does it vary proportionately in some way? It's very annoying - I don't mind going back to single-ended, but it's that raised, then dashed, expectation thing. Anyway that's got a load off my chest. I await your comments with interest. JaFo.
