Not the sort of cable that's ideal for this application. It's designed for wiring applications where movement or vibration is expected and needs to be wired into metal boxes using glands. You wouldn't wire this into your consumer unit unless it's metal, very unlikely, and you would really need a metal socket otherwise you can't gland it off.
Felix makes a valid point, this cable isn't designed for burying it's meant for free air applications, if you bury it you will have to derate it's current capacity.
Do you need 5 cores?
If not just use 2.5 T&E, if you're worried about the cable acting as an aerial then run it in an earthed metal conduit.
Felix, doesn't part P apply only to bathrooms and kitchens and adding a spur to an existing supply is exempt from buiding regs approval?
Kev
