Cartridge or phono preamp - which upgrade first?
Shaggy
Admin/Owner
Administrator
Arizona
Question for the turntable guys. Say someone's running an entry level table with the stock cart, straight into the phono stage built into their receiver, and they've got a few hundred to put toward one upgrade.
Everyone online says the stock cart is the weak link, but plenty of people swear an outboard phono pre makes the bigger difference. Which would you do first, and what would you actually buy at that money?
Cartridge first !!! Plus cleaning all the interconnects and sockets on the amp. Second hand carts are fine, ( mostly ) but make sure that you can obtain new stylii for that particular model. I have a box full of cartridges that would all be very hard to beat, but I cannot buy new stylii.
Outboard phono stages are mostly just an odd on that are a couple of cheap chips ( integrated circuits ) in a little box. Mostly a wallwart power supply which is an abomination to even contemplate. If your amp/receiver is an old analogue one, it may even be prudent to have it overhauled and replace the little electrolytic caps that will abound in 1970's equipment. They dry out and can make a very nice amp or input stage sound attrocious. That in itself can be a problem stemming from the fact that finding
1. An ethical technician
2. An old fella that actually has an understanding of analogue circuitry.
Without denigrating anybody, my own experience with modern techies is they know all about the eye on a seedie player, and nothing about the actual components that make the electronics work.
Today, modern components are relatively easy to find and many are very cheap, but without knowing precisly what type of circuit they are operating in. There are also may modern components that are designed around digital stuff, and are specifically to work with square wave clock signals, NOT analogue flowing voltages and currents.
J.
