A long list that's possibly useful as a reference for the chips and/or mechanisms used in the design of various CD players: ACOUSTIC RESEARCH CD-07 SAA7220 ACCUPHASE DP85 AD1853 NJM4580 ACCUPHASE DP90 PCM63 ADC CD 250XR PCM54 AKAI CD25/26/27/32/36 KSS210A AKAI CD37 PCM67P KSS210A NJM4558 AKAI CD52 KSS210A AKAI CD55 AD1856 KSS210A AKAI CD57 PCM67PJ KSS210 CXD1167Q AKAI CD62 BO38258J AKAI CD650/70 KSS210A AKAI CD69 PCM63 KSS210A AKAI CD-A70 MB84053B KSS123A//BO367214J AKAI CD-M839 PCM56 AKAI CD79 KSS210A AKAI CD750 KSS210A AKAI CD73/93 PCM56 KSS155A(884806401) ALBA CD420 PCM54 ALCHEMIST NEXUS APD32A 2x TDA1549 AMC CD60 PCM1716 AMC CD8A MN6474 (Technics MASH) ANTHEM CD1 PCM1702 ARCAM ALPHA 5 TDA1541 CDM9 ARCAM ALPHA 5 PLUS TDA7310 SAA7220P/B TDA1541A CDM9 ARCAM ALPHA 6 SM5864 ARCAM ALPHA 7 PCM1710 ARCAM ALPHA 7SE PCM1716 ARCAM ALPHA 8 SM5864AP ARCAM ALPHA 9 dCS RingDAC ARCAM CD72 PCM1716 ARCAM CD92 dCS RingDAC ARCAM DELTA 70.2 TDA1541-S1 cdm4/31 ARCAM DELTA 70.3 LM627 ARCAM DELTA 270 PCM69 ARCAM DELTA BOX 5 PCM67 ARYE CX-7 PCM1738 ARYE D-1 PCM1704 AUDIO ALCHEMY ENGINE v3.0 AD1862 AUDIO ANALOGUE MAESTRO AD1855 AUDIO INNOVATIONS ALTO PCM1716 AUDIO NOTE CD-1 PCM1710 AUDIO NOTE CD-2 AD1865 AUDIO NOTE DAC-3 PCM63 AUDIO RESEARCH CD1 SAA7341 AUDIOLAB 8000 CD CS4329 AVI SC2000MC PCM63 BLAUPUNKT CP2650 PCM54 CAMBRIDGE AUDIO CD1 TDA1541 CAMBRIDGE AUDIO CD2 SAA7210 SAA7220P/A 4xTDA1541 CDM2 CAMBRIDGE AUDIO CD3 TDA1541A CAMBRIDGE AUDIO CD4SE CS4327 CAMBRIDGE AUDIO CD6 TDA1305T CAMBRIDGE AUDIO D500 CS4327 CARVER SD/A 450 MN6474 C.E.C. 530CD2 Y3015 C.E.C. 680CD LC7881 CONDOR CD950 YM3020 COPLAND CDA277 PCM63 COPLAND CDA288 PCM63-K CROWN CD2111R LC7881 CYRUS CD7 PCM1716 CYRUS dAD1 TDA1311 CYRUS dAD3 TDA1305 CYRUS dAD3Q AD1861 CYRUS dAD7 AD1861 DENON DA-500 PCM1702 DENON DCD-315 NKS240A DENON DCD-435 PCM1716E DENON DCD-480 PCM61 NKS240A DENON DCD-485 PCM1735 DENON DCD-500 PCM54 KSS123A DENON DCD-520 KSS210A DENON DCD-580 PCM67P NKS240A DENON DCD-590 PCM61 DENON DCD-600 KSS152A DENON DCD-610/20 KSS210A DENON DCD-615/25 NKS240A DENON DCD-635 PCM61P DENON DCD-650F PCM1700P DENON DCD-655 PCM1702 DENON DCD-660 KSS210A DENON DCD-680 PCM69A DENON DCD-685 PCM1702 DENON DCD-690 PCM61 DENON DCD-695 PCM61 DENON DCD-700 PCM54HP KSS123A DENON DCD-715 NKS240A DENON DCD-725 PCM61P-L DENON DCD-735 PCM61 DENON DCD-755AR PCM1702 DENON DCD-800 PCM54 KSS152A DENON DCD-810 KSS210A DENON DCD-820 PCM56 KSS210A DENON DCD-825 NKS240A DENON DCD-860 KSS210A DENON DCD-890 PCM61P NKS240A DENON DCD-895 NKS240A DENON DCD-900 KSS123A DENON DCD-910 KSS210A DENON DCD-920 PCM61 KSS210A DENON DCD-980 PCM61P NKS240A DENON DCD-1015 PCM61P NKS240A DENON DCD-1000 KSS123A DENON DCD-1100 PCM53JP-V KSS123A DENON DCD-1290 NKS240A DENON DCD-1300 KSS123A DENON DCD-1400 PCM56 DENON DCD-1420 PCM54HP KSS210A DENON DCD-1450AR PCM1702 DENON DCD-1500 PCM54HP-K KSS123A DENON DCD-1500mk2 PCM56 KSS151A DENON DCD-1520 PCM64 KSS151A DENON DCD-1530 PCM61 DENON DCD-1550R PCM61 DENON DCD-1550AR PCM61P DENON DCD-1560 PCM1701 DENON DCD-1650R PCM1702 DENON DCD-1700 KSS123A DENON DCD-1800 PCM53 DENON DCD-2060G/80G NKS240A DENON DCD-2560 4x AD1862 DENON DCD-2700 PCM1702J DENON DCD-S10/3000 PCM1702J DENON DCD-3300 PCM56P-K KSS123A DENON DCD-3520 PCM64 KSS151A DENON DCD-3560 PCM58P-K DENON DCD-S1 PCM1702 DENON DCM-280 PCM1748 DENON RCD-100 PCM1710 DENON UCD-F10 PCM61 DENON DN-2000F NKS240A DIORA CD-502 TDA1543 DUAL CD130 CX20017 DUAL CD20 PCM53 EXPOSURE CD TDA1545A EZO FOG STAGE3 AD1853 FISCHER AD935 LC7881 SFP1 FISCHER Z1 PCM58 SFP1 GRUNDIG CD103 LC7881 GRUNDIG CD9000 TDA1541A CDM4.11(£95.00) HARMAN KARDON HD200 YM3020 HARMAN KARDON HD500 PCM53 HARMAN KARDON HD710 MN6474 HARMAN KARDON HD720 PCM1710 HARMAN KARDON HD730 SAA7350 HARMAN KARDON HD760 PCM1702 HARMAN KARDON HD7225 MN6474 HARMAN KARDON HD7300 PCM61 HARMAN KARDON HD7325 MN6474 HARMAN KARDON HD7400/7500 KSS210A HARMAN KARDON HD7525 PCM61P HELIOS MODEL1S CS4328 (36 bit, ETNA) HELIOS MODEL2S CS4328 (36 bit, ETNA) HELIOS MODEL3S CS4328 (36 bit, ETNA) HELIOS STARGATE CS4328 (36 bit, ETNA) HEYBROOK SIGNATURE PCM67 HIGH TECH GOLDLINE CX904 YM3020 JVC XL V22 PCM54 OPTIMA2 JVC XL V221 LC7881 OPTIMA5 JVC XL V250BK PCM56 OPTIMA2 JVC XL V311BK MN6471 OPTIMA4S JVC XL V464 MN35500 OPTIMA6S JVC XL V1100 PCM54 OPTIMA1 KENWOOD DP47 TD6720N KSS152A KENWOOD DP87 KSS152A KENWOOD DP460 TD6709N KENWOOD DP660SG KSS152A KENWOOD DP730 KSS210A KENWOOD DP850 CX20152 KENWOOD DP920/30/50 KSS210A KENWOOD DP1030 KSS210A KENWOOD DP1050 NKS240A KENWOOD DP1060 RCTRH8136 KENWOOD DP1080 LC78620E KENWOOD DP1100D CX20152 KENWOOD DP1510 PCM56 KSS210A KENWOOD DP2000 CX20152 KENWOOD DP2010 PCM56P KSS210A KENWOOD DP2030 KSS210A KENWOOD DP2050 NKS240A KENWOOD DP2060 RCTRH8136 KENWOOD DP2080 LC78620E (LC78820) KENWOOD DP3010/30/50 KSS210A KENWOOD DP3060 NKS240A KENWOOD DP3080 SM5864 KENWOOD DP4030 KSS210A KENWOOD DP4090 KAN03 KENWOOD DP5010/30/40 KSS210A KENWOOD DP5020 PCM1701P KSS210A KENWOOD DP5090 MN35502 JVC KENWOOD DP7002 PCM1702 KENWOOD DP7030 CXD2552 KSS210A KENWOOD DP7040/50 KSS210A KENWOOD DP7060 TDA1547 KENWOOD DP7090 8x PCM1702 KENWOOD DP8020 KSS152A KOREA CHINA CD 022 KDA0316LN KOREA HCD 630 Y3015 KRELL KAV280 PCM1704 LINN GENKI PCM1723 LUXMAN D 102 TD6709N LUXMAN D 103 PCM1701 LUXMAN D 112 1x PCM56 LUXMAN D2 92 LC7881 MARANTZ CD7 TDA1541AS2 (double crown) MARANTZ CD10 SAA7310 TDA1547 CDM4/D36 MARANTZ CD11LE/II TDA1547 CDM4/D36 HDAM MARANTZ CD1010/20 CDM12.1 MARANTZ CD14 TDA1547 CDM12.1 MARANTZ CD15 TDA1547 CDM4-MD MARANTZ CD16D SAA7310 TDA1547 HDAM MARANTZ CD17mkII TDA1370 TDA1547(DAC7) VAM1201 NJM2114/HDAM MARANTZ CD19 SM5872 MARANTZ CD23 CDM9 MARANTZ CD273 CDM2 MARANTZ CD38 TDA1545 CDM12.1 MARANTZ CD385 CDM4 MARANTZ CD40 SAA7310 SAA7220 TDA1541/A CDM4/19 MARANTZ CD42 SAA7310 SAA7350 ? CDM4//691.30209 MARANTZ CD42 II CDM4 MARANTZ CD43 SM5872BS CDM12.1/05 NJM4560 MARANTZ CD45 TDA1540 CDM2/29 MARANTZ CD46 CDM12.1 MARANTZ CD48 TDA1545//1549 CDM12.1 MARANTZ CD50 TDA1541 CDM4/19 MARANTZ CD52 SAA7310 SAA7321GP CDM4 MARANTZ CD52SE SAA7310 SAA7350(Bitstream) CDM4 NE5532 MARANTZ CD53 SM5872BS CDM12.1 NJM2114 MARANTZ CD56 TDA1541 CDM4/25 MARANTZ CD57/57 II CDM12.1 MARANTZ CD583/93 CDM4/19 MARANTZ CD60 TDA1541 A CDM4/19 NE5534 MARANTZ CD63 SM5872BS CDM12.1 HDAM MARANTZ CD63II SM5872 CDM12.1 MARANTZ CD63mkII KI SM5872 CDM12.1 MARANTZ CD63SE SM5872BS CDM12.1 MARANTZ CD65 SAA7310 TDA1541 CDM4/25 MARANTZ CD65 II SAA7210 SAA7220B TDA1541 A CDM4/19 MARANTZ CD67 SM5872 CDM12.1 MARANTZ CD67SE SM5872 CDM12.1 MARANTZ CD67II OSE SM5872 CDM12.1 MARANTZ CD72 SAA7310 SAA7350(Bitstream) CDM4/19 MARANTZ CD72mkII SE SAA7310 TDA1547 CDM 4/28//CDM4/19 HDAM MARANTZ CD73 SAA7000/10 SAA7020 2xTDA1540 CDM1 MARANTZ CD74 SAA7000/10 SAA7020 2xTDA1540 CDM1 MARANTZ CD75 CDM4/25 MARANTZ CD75NB CDM2-160 MARANTZ CD75XNB 691.20464 MARANTZ CD80 TDA1541 CDM1/mkII(CDM4.19) single opamps MARANTZ CD84 TDA1540 CDM1 MARANTZ CD85 CDM1/mkII MARANTZ CD94/mkII TDA1541 CDM1 MARANTZ CD873 CDM2-0500//CDM4/11 MARANTZ CD883 CDM4/19 MARANTZ CD4000 SAA7378 TDA1545 VAM1201 NJM4560 MARANTZ CD5000 SAA7378 TDA1549 VAM1201 NJM4560 MARANTZ CD6000 SAA7378 SM5872 VAM1201 NJM2114 MARANTZ CD6000KI SAA7372 SM5872BS VAM1201 HDAM MARANTZ CD6000OSE SAA7372 2xSM5872 VAM1201 HDAM MARANTZ SA-12S1/SA14 CS4397 HDAM MARK LEVINSON N'36 PCM1702 (vagy PCM1704) MARK LEVINSON No. 390S AD1853 MERIDIAN 508 CS4329 MICROMEGA LEADER SAA7321GP MICROMEGA LOGIC SAA7321 MICROMEGA PREMIUM18 new CS4327 MICROMEGA STAGE2 SAA7321GP MICROMEGA STAGE6 TDA1305 MISSION dAC5 TDA1547 MISSION dAD3 TDA1305 MISSION PCM4000 TDA1541 MITSUBISHI DP109 PCM56 MITSUBISHI MC5100 PCM56 MUSICAL FIDELITY x-ray PCM1716 NE5532 MUSICAL FIDELITY Tri-Vista PCM1738 NE5532 MUSICAL FIDELITY A2 YDC103 MUSICAL FIDELITY DIGILOG TDA1541 MUSICAL FIDELITY E60 YDC103 MUSICAL FIDELITY E624 PCM1716 MYRYAD T-10 CS4327 MYRYAD T-20 CS4327 MYRYAD MC100 CXD2565 NAD 502 MN6474AM KSS210A NAD 510 SAA7350 CDM12.1 NAD 515 CDM12.1 NAD 512 MN6474 KSS210A NAD 522 PCM1710 NAD 5100 PCM56 NAD 5325 LC7881 NAD 5425 MN6471M NAD C520 PCM1710 NAD S500 CS4390 NAIM AUDIO CD1 TDA1541 NAIM AUDIO CD2 TDA1541 NAIM AUDIO CD3 TDA1541 NAIM AUDIO CD3.5 TDA1305 NAIM AUDIO CD5 TDA1305 NAIM AUDIO CDI TDA1541AS1 (single crown) NAIM AUDIO CDS11 PCM1702K NAKAMICHI CD PLAYER 1 PCM1700P NAKAMICHI CD PLAYER 4 AD1864N NAKAMICHI MB 4 LC78840 NAKAMICHI MB 5 LC78840 NAKAMICHI CDP 2E TDA1541A NAKAMICHI OMS 1E PCM56 NAKAMICHI OMS 4E PCM54 NAKAMICHI OMS 5E TDA1540 NAKAMICHI OMS 7E PCM54 NEC CD610 PCM54 ONKYO DX-704 MN6472 (Technics MASH) ONKYO DX-6430 YM3020 ONKYO DX-6470 PCM56 ONKYO DX-6550 Integra TC9219 (ONKYO 8D-3170-1) ONKYO DX-6570 PCM58 ONKYO DX-6620 LC7881 ONKYO DX-7011 TC9237 ONKYO DX-7211 SM5874 ONKYO DX-7500 ONKYO 8S-3380-1 ONKYO DX-7711 Integra SM5864AP ONKYO DX-7911 Integra SM5864AP ORELLE CD100 TDA1541 PARASOUND CD M839 PCM56 PARASOUND C/DP1000 PCM67 PHILIPS AK601/630/640/729/CCD310/320 CDM4/19 PHILIPS CD-80 TDA1541 PHILIPS CD-85M TDA1541 PHILIPS CD-94M TDA1541 PHILIPS CD-100 TDA1540 CDM0 PHILIPS CD-101 TDA1540 CDM1 PHILIPS CD-104 TDA1540 CDM0/CDM1 PHILIPS CD-115/130/140 CDM4/19 PHILIPS CD-150/1 CDM2/29 PHILIPS CD-160 CDM4/25 PHILIPS CD-162/4 CDM4/19 PHILIPS CD-163 CDM12.1/05 PHILIPS CD-200 TDA1540 CDM0 PHILIPS CD-202 TDA1540 CDM0 PHILIPS CD-204 TDA1540 CDM0 PHILIPS CD-210 TDA1543 CDM4/19 PHILIPS CD-210 CDM4/19 PHILIPS CD-300/303 SAA7210 SAA7020 2xTDA1540 CDM1 PHILIPS CD-304 TDA1540 CDM1 PHILIPS CD-304 MkII (alu chassis) SAA7210 SAA7220P/A TDA1541 CDM1 PHILIPS CD-310 CDM4/19 PHILIPS CD-340 CDM4/19 PHILIPS CD-350 TDA1541 CDM2/29 PHILIPS CD-360 CDM2 //CDM4/25 PHILIPS CD-371/3 CDM4/11 PHILIPS CD-380 TDA1543/1/1A CDM4/19 PHILIPS CD-410 CDM12.1/05 PHILIPS CD-460 TDA1541 CDM2 //CDM4/25 PHILIPS CD-465 TDA1541 PHILIPS CD-470 PHILIPS CD-471 TDA1541 CDM4/11 PHILIPS CD-472 TDA1541 CDM4/11 PHILIPS CD-473 TDA1541 CDM4/11 PHILIPS CD-480/2 TDA1543 CDM4/19 PHILIPS CD-500/2 CDM4/19 PHILIPS CD-560 CDM2 //CDM4/25 PHILIPS CD-581/2 TDA1541 CDM4/19 PHILIPS CD-583/4 CDM4/19 PHILIPS CD-586 CDM4/19 PHILIPS CD-600/4/5 CDM4/19 PHILIPS CD-610 SAA7310 SAA7220P TDA1541 CDM4/19 PHILIPS CD-604 TDA1543 CDM4/19 PHILIPS CD-614/15 TDA1543 CDM4/19 PHILIPS CD-618 Bitstream ? CDM4/19 PHILIPS CD-620 TDA1541 ? CDM4/19 PHILIPS CD-621 SAA7345 PHILIPS CD-624 SAA7323 CDM4/19 PHILIPS CD-630 SAA7220P/B TDA1541 CDM4/19 PHILIPS CD-634 Bitstream ? CDM4/19 PHILIPS CD-640 TDA1541 PHILIPS CD-650 SAA7210 SAA7220P/A TDA1541 CDM2/29//CDM4/25 PHILIPS CD-660 CDM4/11 PHILIPS CD-670 SAA7210 SAA7220P/A TDA1541 CDM4/11//(69130212) LM833 slim size, plastic case, SPDIF PHILIPS CD-690 Bitstream ? RCD1.2D PHILIPS CD-692 Bitstream ? CDM9/63 PHILIPS CD-710/720 CDM12.1/05 PHILIPS CD-723 SAA7378 TDA1545 VAM1201 NJM4560 PHILIPS CD-733/740 CDM12.1/05 PHILIPS CD-751 SAA7378 TDA1549 CDM12.1/05 PHILIPS CD-750 SAA7378 TDA1549 CDM12.1/05 PHILIPS CD-753 SAA7378 TDA1549 VAM1201 NJM4560 PHILIPS CD-771 CDM2-0500//CDM4/11 PHILIPS CD-780/1 CDM4/19 PHILIPS CD-782 TDA1541 CDM4/19 PHILIPS CD-820 SAA7220 TDA1541 A CDM4/19 LM833 PHILIPS CD-830 CDM4/19 PHILIPS CD-824/834 CDM4/19 PHILIPS CD-840 Bitstream CDM4/19 PHILIPS CD-850 TDA1541 CDM4/19 LM833 PHILIPS CD-880 TDA1541 S1 CDM1 mkII PHILIPS CD-882 CDM1 mkII//691.20449 PHILIPS CD-883 CDM4/19 PHILIPS CD-910/11 SAA7341GP (4822-691-20768) CDM12.1/05//RCD1.2D PHILIPS CD-930/1 TDA1547 CDM9/44 PHILIPS CD-920/1 CDM12.1/05//RCD1.2D PHILIPS CD-930/1 TDA1547 CDM9/44 PHILIPS CD-940 CDM9/44 PHILIPS CD-950 TDA1547 CDM9/44 PHILIPS CD-950/1 TDA1547 CDM9/44 PHILIPS CD-960 TDA1541 CDM1/mkII ??? NE5534 PHILIPS LHH-100 TDA1547 PHILIPS LHH-500 TDA1547 PHILIPS LHH-600 TDA1547 PHILIPS LHH-800 TDA1547 PHILIPS LHH-1000 TDA1541 PHILIPS MAGNAVOX CDB-560 TDA1541 PHILIPS MAGNAVOX CDB-650 TDA1541 PINK TRIANGLE NUMERAL TDA1305T PIONEER DV-717 PE8001A PIONEER PD40S PWY1010 PIONEER PD75 PD2028A PIONEER PD93 PD2028A PIONEER PD95 PD2028A PIONEER PD-102/3 PEA1179 PIONEER PD-202/3 PEA1179 PIONEER PD-204 PD2026B PIONEER PD-970 PEA1030 PIONEER PD-4050 PWY1010 PIONEER PD-4500 PCM1700 PEA1030 PIONEER PD-4700/5700/6500/67000/7700/8700 PEA1030 PIONEER PD-4550 PCM1700P PEA1030 PIONEER PD-5100 PD0034 PWY1010 PIONEER PD-52 PEA1030 PIONEER PD-5300 PCM56 PWY1010 PIONEER PD-54 PEA1179 PIONEER PD-5500 PEA1030 PIONEER PD-5050 PWY1010 PIONEER PD-5700 PD2026A PEA1030 PIONEER PD-6050/6100/6300 PWY1010 PIONEER PD-65/6500/6700 PEA1030 PIONEER PD-7050 PWY1010 PIONEER PD-7300 PCM58P PIONEER PD-7300/7500/7700/8700 PEA1030 PIONEER PDR-04 AKM4321 PIONEER PDR-609 PCM1716 PIONEER PDR-W739 PCM1716 PIONEER PDR-W839 PCM1716 PIONEER PDS-06 PCM1702J PIONEER PD-S303 PEA1030 NJM 4558/4580 PIONEER PD-S501 PEA1030 NJM 4558/4580 PIONEER PD-S502 PD2026B PEA1179 NJM 4558/4580 PIONEER PD-S503 PEA1179 NJM 4558/4580 PIONEER PD-S505 PD2029A PEA1030 NJM 4558/4580 PIONEER PD-S507 CXD2507aq PE8001A NJM 4558/4580 PIONEER PD-S602/3 PEA1179 NJM 4558/4580 PIONEER PD-S601/701 PEA1030 NJM 4558/4580 PIONEER PD-S702 PEA1179 NJM 4558/4580 PIONEER PD-S703 PD2029A PEA1179 NJM 4558/4580 PIONEER PD-S707 PEA1030 NJM 4558/4580 PIONEER PD-S801 PD2028 PIONEER PD-S802 PD0116A PEA1179 PIONEER PD-S901 PD2028B PEA1030 PIONEER PD-S909/990 PEA1030 PRIMARE D20 AKM4324 PRIMARE D302 4x PCM1702 PROCEED PCD2 PCM58P PROTON AC423 LC78820 PROTON AC424 TDA1311A QUAD66 TDA1541A QUAD77 CS4328 REGA PLANET PCM1710U REVOX B225 TDA1540 REVOX B226 TDA1541 NE5534 REVOX C221 SAA7310 ROKSAN ATTESSA DP3P CS4328 ROKSAN CASPIAN TDA1305 ROTEL RCD-02 PCM1732 ROTEL DCM-9PRO PCM63 ROTEL RCD-855 TDA1541 CDM4/19 ROTEL RCD-856BX SAA7323 ROTEL RCD-865BX SAA7323 ROTEL RCD-945AX SAA7341GP T ROTEL RCD-955 TDA1541 ROTEL RCD-965BX SAA7323GP T ROTEL RCD-970BX TDA1305T ROTEL RCD-971 PCM63 ROTEL RCD-975 TDA1305T ROTEL RCD-991 PCM63P ROTEL RCD-1070 PCM1732 SANSUI CD V1000 PCM56 SANYO CP489 LC7881 SEG CD200 YM3020 SHARP DX112 IR 3K16BM SHARP DX650 LC7880 SHERWOOD CD1 TDA1547 SHERWOOD CD1060C D6372 CX SHERWOOD CD1160R PCM56 SHERWOOD CD1192R YM4113B SHERWOOD CDC2000C μPD6376 SHERWOOD CDC2010RC μPD6376 SHERWOOD CD4030R SAA7350BS SIMAUDIO MOON ECLIPSE 4x PCM1704K SONIC FRONTIERS SFCD1 UltraAnalog D20400A SONY CDP-25/356 KSS120C SONY CDP-203/30/45/50/55/65/70 KSS121A SONY CDP-40 1x PCM54 SONY CDP-101 CX20017 SONY CDP-222ES PCM56P J SONY CDP-227ESD TDA1541 SONY CDP-228ESD PCM58P KSS151A SONY CDP-302ES CX20152 SONY CDP-333ESA CXD2562 SONY CDP-333ESD TDA1541 SONY CDP-333ESJ CXD2562 SONY CDP-337ESD 2xTDA1541A SONY CDP-497 CXD2561 SONY CDP-502 PCM54 SONY CDP-502ES CX20152 SONY CDP-552 PCM54 SONY CDP-553ESD PCM53JP-V K SONY CDP-555ESA CXD2562 SONY CDP-555ESD TDA1541A SONY CDP-555ESJ CXD2562 SONY CDP-620 CX23034 PCM54 SONY CDP-650 PCM54 SONY CDP-701ES CX20017 SONY CDP-777ESA CXD2562Q SONY CDP-M18 CXD2500Q CXD2554M KSS240A SONY CDP-MS1 CXD8594 + CXA8042AS SONY CDP-R3 + DAS-R1a CXD2552Q + CXD2552 SONY CDP-X229ES CXD2562Q NKS240A SONY CDP-X3000 CXD2562Q + CXA8042AS SONY CDP-X303ES CXD2562Q SONY CDP-X5000 CXD2515 CXD2562 + CXA8042 SONY CDP-X505ES CXD2562Q SONY CDP-X33ES CXD2552Q SONY CDP-X55ES CXD2552 KSS270A SONY CDP-X777ES CXD2552BQ SONY CDP-X779ES CXD2562 SONY CDP-X77ES CXD2552 KSS280A SONY CDP-X7ESD PCM58P S KSS190A SONY CDP-X900 CXA8042 SONY CDP-XA30ES CXD2562Q + CXA8042AS KSS160B SONY CDP-XA50ES CXA8042AS SONY CDP-XA55ES CXD8594Q + CXA8042S KSS310A SONY CDP-XA5ES CXD2562Q + CXA8042AS SONY CDP-XA7ES CXD2562 + CXA8042AS SONY CDP-XB920 CXD8715 + CXA8355 SONY CDP-XB720E CXD8735N SONY CDP-XB930 CXD8735N SONY CDP-XE300 CXD8567 SONY CDP-XE330 CXD2529Q SONY CDP-XE900 CXD8505 + CXA8055 KSS213B SONY DAS-R1 4XTDA1541AS1 (single crown) SONY CDX11/20/80/5B KSS160B SONY CDXA15/20/30 KSS160B SOUND WAVE CD1100 LC7881 SUDGEN OPTIMA TDA1543 SUDGEN SDA-1 TDA1541 SUDGEN SDT-1 TDA1541AS1 (single crown) T+A CD1210R SM5864AP TAG McLAREN CD20R CS4329 TALK ELECTRONICS THUNDER 3 CS4390 TASCAM CD201 MN6474 TEAC PD155mk2 Y3015 TEAC PD160 TC9218F 9A01026600 TEAC CPD3450SE YDC103LSI OPAxx TEAC CPD3100/4100 KSS210A TEAC PD365 YM7121B TEAC VRDS 7 TDA1547 TEAC VRDS 8 PCM1702 TEAC VRDS 9 PCM1702 TEAC VRDS 10SE TDA1547 TEAC VRDS 25 AD1862J TEAC ZD5000 PCM53 TECHNICS SL-P1 PCM53 TECHNICS SL-P2 PCM53 TECHNICS SL-P110 PCM54HP TECHNICS SL-P120K E PCM54HP TECHNICS SL-P272A MN6474 TECHNICS SL-P202/212/222 CDM4/19 TECHNICS SL-P177/277/377/477 A CDM4/19 TECHNICS SL-P1200 PCM54HP TECHNICS SL-P360/70/460/70/570 CDM12.1/05 TECHNICS SL-PG480A MN662713 CDM12.1/05 TECHNICS SL-PG100/200/400/420/440/500/520/540 CDM4/19 TECHNICS SL-PJ28A MN6477 CDM4/19 TECHNICS SL-PJ24/26/27/28/37/325/46 CDM4/19 TECHNICS SL-PS620 CDM4/19 TECHNICS SL-PS670D MN6474 CDM12.1/05 TECHNICS SL-PS700 MN6474 SOAD70A TECHNICS SL-PS740A CDM4/19 TECHNICS SL-PS770A MN6473 CDM12.1/05 TECHNICS SL-PS840/900A SOAD70A THETA DSP PCM67 THOMSON LAD300 TD6720N THULE CD100 CS4303 THULE SPIRIT PCM1715U TOSHIBA XR40 TD6705AP UHER UCD-210 LC7882 UNIVERSUM CD4682 PCM56 USHER CD-100 PCM1732 WADIA 850 PCM1702 WADIA 860 4x PCM1702 WADIA 861 4x PCM1704 YAMAHA CD-2 PCM53 YAMAHA CD-3 PCM53 YAMAHA CD-2000 PCM54HP YAMAHA CDX-3 PCM54 YAMAHA CDX-410 PCM56 YAMAHA CDX-420 PCM56 YAMAHA CDX-450 KSS210A YAMAHA CDX-470 YDC103 KSS210A YAMAHA CDX-480 MN66271 KSS210A YAMAHA CDX-490 MN66271R YAMAHA CDX-580 YAC514 KSS210A YAMAHA CDX-590 YAC514 YAMAHA CDX-593 YAC514 YAMAHA CDX-700 PCM56 YAMAHA CDX-750/860 KSS210A YAMAHA CDX-880 YAC514 KSS210A YAMAHA CDX-900 PCM56 YAMAHA CDX-890 YAC514 YAMAHA CDX-893 YAC514 YAMAHA CDX-993 YAC514F YAMAHA CDX-1100 PCM56 YAMAHA CDX-2020 PCM58
