For Sale: Clearaudio Maestro Wood MM
alanbeeb
Grumpy young fogey
Edinburgh
Probably the best MM cart you can get. I've only used this for about 15 hours, but have decided I want to try a bigger range of MCs.
Cost nearly £400 new, looking for £300 incl. special delivery.
The one I am selling is in satine wood, which is a sort of dark reddish brown, gives a slightly warmer sound than the metal bodied version.
Specs:
Frequency response
20 Hz - 20 kHz
Output voltage
(1 kHz, 5 cm/s): ~ 3,6 mV
Channel Separation
(1 kHz): > 30 dB
Channel balance
(1 kHz): < 0,2 dB
Trackability
> 90 µm
Recommended tracking force
2,0 - 2,5 g: 2,2 g
Coil impedance
(1 kHz): 0,66 kOhm
Coil inductivity
0,42 H
Loading impedance
48 kOhm
Loading capacity
100 pF
Cantilever
Boron
Weight (Stainless steel)
12,0 g
Weight (Wood)
7,0 g
