Connecting my PC to my hifi - help needed
Discussion in 'Hi-Fi and General Audio' started by Gr0ver, Sep 30, 2003.
  1. Gr0ver
    Gr0ver
    Sep 30, 2003
    6
    Evening all.
    I'm trying to connect the digital-out of my Audigy soundcard to the optical-in of my hifi.
    I'm not getting any sound though.
    Might it be the cable? All ends fit perfectly...but it's just a random one I borrowed off a mate. Do I need a specific one or something?
    Any help would be much appreciated, as I've tinkered with the card's setting MUCHLY.
    Cheers in advance,
    Ian.
    (PS. I was referred to here by davidcotton, so props to him:))
  2. Gr0ver
    PBirkett VTEC Addict
    2,456
    The Toon
    Does Audigy have an optical out? I always assumed it to have co-ax but I could be wrong, as I washed my hands of that rubbish a long time ago.
    My guess is that you need to enable the digital output in the control panel, but I've never used an Audigy so I cant really offer any more help than that....
    PBirkett, Sep 30, 2003
  3. Gr0ver
    Gr0ver
    Sep 30, 2003
    6
    It's got a digital-out...
    That's what I'm trying to connect to the optical-in of my hifi.
    No luck though.
    I have no knowledge of anything audio-related, mind, so it could be anything really. Annoyingly.
  4. Gr0ver
    2,456
    The Toon
    Is the digital output on the Audigy a minijack output though?
    The reason I am asking is because my old Videologic Sonicfury had digital out through a minijack (like a little headphone connector), and that was co-axial. However, sometimes these connections are optical too. But if it is co-ax, then plugging into optical wont work (unless you buy a converter).
    Of course it may have an optical out in which case I am talking bollocks. The thing is, I dont know what connections the Audigy has. I'll do some digging for you.
  5. Gr0ver
    2,456
    The Toon
    OK I've just found this:-
  6. Gr0ver
    Gr0ver
    Sep 30, 2003
    6
    Cheers for the help mate, it's much appreciated.
    I think you're right in thinking that it's digital out through a mini-jack...and so co-axial.
    Sorry to bother you more, but do you know what would be the best way of connecting it to my hifi then? I don't actually know what co-axial means, unfortunately.
    Should I get an adapter and connect it to the optical-in?
    Or some kind of cable to connect it to the analogue-ins (red/white)? There's even a PC Link socket thingy....looks like a mouse or keyboard port on a mainboard.
    Cheers in advance,
    Ian.
    Gr0ver, Oct 7, 2003
  7. Gr0ver
    Gr0ver
    Sep 30, 2003
    6
    I've been checking out maplin.co.uk and was just wondering if a Coaxial to Optical Digital Signal Convertor would be the appropriate thing to get?
    If so, what kind of cable would I need to connect the digital-out of my soundcard to the converter?
    (I think I already have the cable that connects the converter to my hifi's optical-in)
    Thanks in advance,
    Ian.
    Gr0ver, Oct 7, 2003
  8. Gr0ver
    2,456
    The Toon
    Well mate, for a minijack you can use a normal electrical cable, but I'd ask the question do you HAVE to use optical? Thing is, you could get a converter, but chances are it wont be for a minijack, it'll be for RCA. So on top of this converter, you'll have a minijack to RCA adapter as well. There is then 2 possible places to degrade the quality as well as the fact of the SB resampling internally to 48Khz, so the digital output quality might not be so hot...
    Also I dont know how much one of these converters costs, but Hoontech make a low cost card (around £50) with optical outputs and no resampling which sounds like it'd be better for his needs. Then he can always flog the Audigy for £20 or something...
    PBirkett, Oct 7, 2003
  9. Gr0ver
    rob SCHMOOOOKIN
    Aug 21, 2003
    640
    cardiff.
    ive used the out (mini jack) that my computers speakers were connected to. does this mean that the signal is pre amped as now i have two volumes? computer and amp.
    rob, Oct 7, 2003
  10. Gr0ver
    2,456
    The Toon
    Rob, yes it does mean that, but that is not always a bad thing. My Terratec has a volume control that works up to 0 db which presumably prevents clipping, although I dont know about your card.... Normally though, I had the volume maxxed unless there is audible distortion on the soundcard (better S/N ratio I think)
  11. Gr0ver
    Phill77
    Aug 10, 2003
    74
    Phill77, Oct 7, 2003
  12. Gr0ver
    2,456
    The Toon
    Never heard of it, but it might be alright so long as it doesnt internally resample - it basically just looks like a digital soundcard, not much different to anything else.
    The only soundcard that sounds any good which resamples is the Videologic Sonicfury (Turtle Beach Santa Cruz), and these can be found for less money. Still not optimal though...
    Maybe something like a USB stereo link might be an option worth looking into, although I've never looked into it with any depth.
  13. Gr0ver
    Gr0ver
    Sep 30, 2003
    6
    I was thinking about that PB, but the one I looked at was like 60-70 quid, which put me off a bit.
    And I don't really want to get a new soundcard, as my Audigy is fab for games and I only got it (relatively) recently.
    So yeah. I'll have to work out what to do.
    But thanks once again.
    I really appreciate all the help.
    Ian.
    Gr0ver, Oct 7, 2003
  14. Gr0ver
    technobear Ursine Audiophile
    Jun 22, 2003
    2,099
    Glastonbury
    So what is the hifi component that you are trying to connect to. Seems strange that it only has an optical digital in and no electrical (coax) digital in.
    The Audigy has a reasonable line out. Why not just connect that to a spare line in on your hifi and see how it sounds. All you need for that is a mini-jack to phono lead.
    technobear, Oct 7, 2003
  15. Gr0ver
    Gr0ver
    Sep 30, 2003
    6
    It's a Sony Micro System mate.
    CMT-M100MD to be precise :)
    It's got a PC link, an optical in, analogue in (those red and white things) and that's it really.
    I might try a non-optical connection like you said though.
    Cheers mon,
    Ian.
    Gr0ver, Oct 7, 2003
  16. Gr0ver
    Jun 22, 2003
    2,099
    Glastonbury
    And does the 'MD' perhaps stand for MiniDisc. If that is so then the optical in would be there so that you can make direct digital recordings from a suitable CD player onto MiniDisc.
    If you are not making MiniDisc recordings from the PC, but are only playing music, then I would suggest the DAC in the Audigy will be no worse (possibly even better) than the one in the mini system and that you will get decent sound using just an analogue connection from the 'line out' socket on the sound card to the analogue inputs (red and white as you said) on the mini system.
    You need a lead with 3.5mm Stereo Jack Plug and two RCA Phono plugs. These are not hard to come by. Even your local Dixons should have one.
    technobear, Oct 8, 2003
